Which carb? '74
Old Dec 11, 2008 | 07:44 PM
kmobrien76's Avatar
kmobrien76
Default Which carb? '74
Not too mechanically inclined, might give my babe a new carb for the '09 season, hopefully clear up some issues..
I have the 350 engine, 3 spd auto, mild cam, low HP engine, 195 when stock, can someone point me to a link where I can find replacement, didn't see one one ecklers site..
Thanks all,
Kevin
'74 Vette
Old Dec 11, 2008 | 08:30 PM
Mike Ward's Avatar
Mike Ward
What's wrong with the one you've got? An aftermarket carb will NOT give you more HP.
Old Dec 12, 2008 | 09:22 AM
kmobrien76's Avatar
kmobrien76
Default carb
Runs like (*&$(&$#(&(@$(*&@#$(*&(*#@&$(*&#(@$@#$
might need more adjusting, will try that before we replace, but was curious where I can get one efficiently and cost...
Kevin
Old Dec 12, 2008 | 09:40 AM
Paul L's Avatar
Paul L
I got a "correct" #7044206 (195hp, A/T) from NAPA. I believe they keep a computerized database of numbers. Some people poo-poo remanufactured carbs but it has worked well.
This is the company that does the work. They are located in Winnipeg, Manitoba.
http://www.autoline.ca/carburetors.htm
Old Dec 12, 2008 | 10:22 AM
Dave C's Avatar
Dave C
Hi Kevin - nice to see another MASS owned Med Blue 74! I'd do what Paul says - go to NAPA, get a reman'd carb, then get the original rebuilt if you care about keeping it original... or keep it on the shelf. Don't forget the STABIL in your gas while the car is sleeping during the winter!!
I did a quick scan on the local Craig's List and this is what I turned up - GOOD LUCK!
http://boston.craigslist.org/sob/pts/953197720.html
http://boston.craigslist.org/gbs/pts/951490510.html
http://boston.craigslist.org/gbs/pts/954806972.html
Dave
74 L-82 Roadster
Wakefield, MA
Old Mar 20, 2009 | 04:43 PM
kmobrien76's Avatar
kmobrien76
Default carb
Thanks everyone!
Vehicel is in shop now, thinking perhaps an Edelbrock carb to clear things up...
Brought it to Les Lucier, Brockton, recommended by forum member here!
Kevin
Dave
74 L-82 Roadster
Wakefield, MA
Old Mar 20, 2009 | 05:25 PM
Ganey's Avatar
Ganey
If you have the stock iron intake you need a spreadbore carb like Q-J or Holley replacements. Adapter height is an issue for square bore like Edel. Carter.
CARBS Tests TQ/HP
http://www.corvettefaq.com/c3/carbcomparo.htm
Old Mar 20, 2009 | 05:38 PM
kmobrien76's Avatar
kmobrien76
Wow, good tip, I'll call the shop and pass that along!
KO
To Which carb? '74
