Buildsheet
Old Dec 12, 2008 | 09:47 AM
law dog's Avatar
law dog
Default Buildsheet
My 77 Corvette is all original. I`m told the buildsheet could be in three different locations. Under the carpet, between the tach & speedo or, above the fuel tank. Where is/was the most common place?
Old Dec 12, 2008 | 10:00 AM
eastltd's Avatar
eastltd
Check above the fuel tank first. You may be able to see it through filler door with a flash light.
Old Dec 12, 2008 | 10:03 AM
Durango_Boy's Avatar
Durango_Boy
On you're '77 it's in a 4th place unique to the Vettes that have that metal shroud around the tank. I found that out when I dropped my '77 tank and found no sheet. I then dropped the metal shroud that's bolted in the cavity the tank is in...bolts holding it to the frame.
It came down and sure enough, there was the blank sheet glued to the shroud.
Old Dec 12, 2008 | 10:08 AM
law dog's Avatar
law dog
Thanks, I`ll start there first.
Durango Boy.....were you able to read it?
Bobz08C6's Avatar
Bobz08C6
On top of the tank almost everytime.
Old Dec 12, 2008 | 10:09 AM
Durango_Boy
No, sadly, even though the sheet was almost perfect...the ink was long gone. I didn't even keep it simply because it was just an old piece of blank paper.
Old Dec 12, 2008 | 10:16 AM
law dog's Avatar
law dog
That`s too bad. Kind of a lousy place for GM to put it. If mine is there it`s probably in the same shape. Although, my car has been a So. Ca. car all it`s life and was in dry storage for 10 years.
Old Dec 12, 2008 | 11:44 AM
smon's Avatar
smon
I found my 75's sheet on top of that frame just like DBs. I was able to get mine out by reaching up the side of the tank where you can get to the holes for rack. I slid my hand under it and removed the glue from the metal without tearing the paper. Mine was also covered with about a quarter inch of dust, I could see some writing but if I tried to wipe or blow the dust off, the ink came off with it. I can read a couple small parts, but I dont think its worth keeping.
Good luck,
Sean
Old Dec 12, 2008 | 11:54 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...Kind of a lousy place for GM to put it...
Considering why it's there, it served it's purpose rather well. Build sheets on the tank were never meant to be permanent and were meant to be only aids to assembly line workers for assembly of the car. Until body drop, anyone could take a look at the tank sticker and determine what equipment was to be installed on the car. Most Corvettes also had a copy of the build sheet taped to the nose, but those got trashed after the car was completed and ready for roll out.
Quality of the pic is not the best, buy you can see the tank sticker on the white car. If you look closely at the car behind it, you can see a second copy of the build sheet taped to the nose, just left of the center line.
Later production, build sheets were taped to the fuel tank.
77-81 owners might be able to obtain a copy of their factory invoice by checking with Allied-Vaughn. http://www.corvetteactioncenter.com/...x.php?cmd=area
The invoice will have the same items as on the build sheet, plus additional information not on the build sheet. Beats the heck out of dropping the tank.
Old Dec 12, 2008 | 09:06 PM
law dog's Avatar
law dog
Easy Mike.....thanks for the info, I also enjoyed the photo`s.
Old Dec 12, 2008 | 10:41 PM
RetiredMarine20's Avatar
RetiredMarine20
If you can find it, scan it and send it to me. I have guys who can work miracles with seemingly blank papers.
Old Dec 13, 2008 | 08:01 AM
7T1vette's Avatar
7T1vette
Document examiners/restorers can "work miracles" with the original paper...not with a scanned image.
Old Dec 13, 2008 | 11:04 AM
Durango_Boy
Sorry I am pretty sure I tossed it. I had a friend look at it and he works with ancient parchments at the University. The ink was literally gone and the paper had been saturated with dust and water for so long that any residuals from the ink were ruined.
Old Dec 13, 2008 | 12:31 PM
mapman's Avatar
mapman
The build sheet on my 1980 was mostly legible but the paper was fragile and dust covered. However, I got a copy of the shipping document from GM Archives, it contained the same option information as what was legible on the build sheet and it has much the same information as the window sticker. From your profile I see you have a 1977 - I believe the shipping documents are available for that year. You might check them out. The service is now performed by a vendor for GM.
Old Dec 13, 2008 | 01:22 PM
hwcoop's Avatar
hwcoop
I love the pic of that 69 at body drop....now my desktop
I was pretty lucky with mine, here it is after 35years on top of my tank
which is pretty amazing when you consider what my frame and rocker channels looked like
Old Dec 13, 2008 | 05:39 PM
74 LS4-454's Avatar
74 LS4-454
Finalist 2020 C4 of the Year - Unmodified
Default I also lucked out....
with the buildsheet, I tend to think that it was under the carpet, as that has been replaced, due to a vistor who tried to set up home there. the previous owner did not want to take any chances with his little friend, so they replaced the entire carpet.
Old Dec 14, 2008 | 05:52 AM
hunt4cleanair's Avatar
hunt4cleanair
I'm guessing this is for a 75 convertible? I've not seen a 75 convertible build sheet so its got my curiosity.
It was not unusual for workers to place them, actually leave them, under the carpet. The only "standard" practice was the tank sticker for use by the chassis line workers as they built up the chassis before body/chassis marriage.
To Buildsheet
Old Dec 14, 2008 | 06:13 AM
C3Paul's Avatar
C3Paul
This is exactly the same place where I found my Build sheet, last week.
Old Dec 14, 2008 | 10:32 AM
RetiredMarine20
Do it for a living during site exploitation in various parts of the world while supporting the Marines. All has to do with the quality of the scan and the photo editing software that we use.
Old Dec 14, 2008 | 05:18 PM
74 LS4-454's Avatar
74 LS4-454
it is for a 74 Vert....
