WTK:Scratch Remover
Old Dec 16, 2008 | 01:22 PM
corvetteload's Avatar
corvetteload
Default WTK:Scratch Remover
Has anyone ever tried that scratch remover pen that is shown on the info-mercial by that Billy guy?!?!?!?!?! Just wondering how it work on minor blemishes. OR- any other item that can be recommended, thanks.................................B ruce
Old Dec 16, 2008 | 02:55 PM
Durango_Boy's Avatar
Durango_Boy
Billy Mays.
The product is a quick and easy way to get money out of your wallet.
Do you have a specific ding you need fixed or just a bunch of them?
Old Dec 16, 2008 | 03:10 PM
Flying Low's Avatar
Flying Low
Scratch-x can be had at walmart or parts houses.
It is great. you just about can not screw up using it.
They call it "diminishing abrasive technology"
David
Old Dec 16, 2008 | 03:15 PM
Duke94's Avatar
Duke94
I've used the Scratch-X also. It works well on scratches that are not through the paint. If you have scratches through the paint and the primer shows, you'll need some kind of touch up paint. Forget Billy Mays.
Old Dec 16, 2008 | 04:48 PM
Durango_Boy
David
Sounds like wet sanding and buffing to me, but without all the work. Wonder why body shops haven't gone out of business with a product like that.
Old Dec 17, 2008 | 12:48 AM
7T1vette's Avatar
7T1vette
I thought it only masked scratches in the clear coat layer???
Old Dec 17, 2008 | 10:45 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Same here. Might work for clear coat cars.
Old Dec 17, 2008 | 12:33 PM
jnb5101's Avatar
jnb5101
to me, it looks as though the video is run backwards when the scratch is "being repaired".
Old Dec 17, 2008 | 03:18 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by jnb5101
...it looks as though the video is run backwards...
When you run it backwards, do you get your old girlfriend and your dog back?
Old Dec 17, 2008 | 04:06 PM
jnb5101's Avatar
jnb5101
only south of the mason-dixon line!
Old Dec 17, 2008 | 06:40 PM
VCuomo's Avatar
VCuomo
Hmmm...getting back my old girlfriend's parts south of the mason-dixon line might not be so bad... I liked those parts!
Old Dec 17, 2008 | 08:43 PM
TMU's Avatar
TMU
St. Jude Donor '09-'10, '15, '17
Scratch-X works pretty good, seems to be a somewhat typical fine grit polish but a little more expensive per volume. I'd say it's one step before resorting to some 2000 (or finer) paper wet sanding followed by polishing. Unless you want to try a more abrasive polish instead of the paper.
Man I hardly ever run into my old girlfiends anymore, but if its someone I've had some conflict with, I bump into them somehwere.
To WTK:Scratch Remover
