Interior trim paint
Old Jan 15, 2009 | 09:44 AM
tyancey00's Avatar
tyancey00
Default Interior trim paint
what is the best way to clean the plastic parts before I repaint them? I am also going to reuse the arm rest. Same stuff? as far as dye?
Old Jan 15, 2009 | 10:19 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Soap and water first to get rid of the gook. Any type of pre-paint degreaser after that as long as it doesn't eat vinyl.
Old Jan 15, 2009 | 11:05 AM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
I agree, soap and water only. if your interior is black, I reccomend Wurth Satin spray paint.......
Old Jan 15, 2009 | 11:21 AM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
Do it more than once. Decades of cigarette smoke and air pollutants are on those parts. The end result will be determined by how clean the parts are.
Old Jan 15, 2009 | 05:04 PM
tyancey00's Avatar
tyancey00
looks like I am in the kitchen this weekend. Gotta have her back together by Feb 14th!!
Old Jan 15, 2009 | 05:15 PM
WillEE's Avatar
WillEE
I was told to use denatured alcohol. It worked very well. Yes - once you think you really got it clean - do it a couple more times. One thing I recommend - look very closely at your plastic before painting it. I had some fibers from the cleaning rags cling to some parts of the plastic (esp. where a chip in it exists). I didn't see them till the paint was applied. Mostly got them off after paint dried but thught worth mentioning. Was very happy with the finished product.
Old Jan 15, 2009 | 05:24 PM
75 Red Vert's Avatar
75 Red Vert
I used dawn grease remover dish soap & washed everything twice, then rinsed twice with warm water, then wiped down wirh denatured alcohol then spwayed with light coats. Call if U need help!
Old Jan 15, 2009 | 05:32 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
I'll have to check my can at home to see exactly what I have, but it was recommended by some forum members to me. It is an EXACT match to the factory black plastic and is available at your local parts store.
Old Jan 15, 2009 | 09:01 PM
7T1vette's Avatar
7T1vette
If you use spray paint, it will tend to fill in the surface grain, will be subject to chipping and peeling, and you will always have to use paint thereafter. If you use vinyl dye [like the parts were originally colored], it will not fill the grain, it will not chip or peel, and you can re-color it any color with vinyl dye as many times as you want. Do what you will....
To Interior trim paint
