1971 Wiper Problem
Old Jan 28, 2009 | 02:24 PM
wallifishrmn's Avatar
wallifishrmn
Default 1971 Wiper Problem
When I turn the wipers off the passanger side wiper doesn't seem to go down far enough the trip the interlock valve. I know you can adjust the valve--needs to come up 1/16 inch but the wiper looks like it should go down farther. Any adjustment on the wiper. Everything else works great and the drivers wiper goes all the way down to the stop. When the door comes down its hits the top of the passenger wiper. Is this normal?
Old Jan 28, 2009 | 02:48 PM
PETKAH's Avatar
PETKAH
Make sure your LH wiper goes completely down - if not it will prevent the RH wiper from coming down on the relay valve. Hopefully all you have to do is adjust the LH wiper further down. This worked for me. NOTE: look closely at the LH wiper it may be seated but bent up so the RH wiper does not seat. The door should not touch the wiper at all.
Old Jan 28, 2009 | 02:49 PM
Alan 71's Avatar
Alan 71
Hi W,
The adjustment at the wiper motor shaft determines how far down the wiper transmission shaft pulls the wiper arm. The driver's side blade rests against the stop plate first, and then the passenger's side. The adjustment procedure is on UPC 1, Sheet D6.
This picture show the adjustment at the wiper motor in the wiper well. It's those 4 nuts and 2 plates under the grill mounting bracket.
Regards,
Alan
Old Jan 28, 2009 | 04:58 PM
wallifishrmn
I adjusted the the shaft as far as it would go and now my wiper door won't go down--just stays up. Whomever thought up the vacuum system for wipers and lights should be shot. Must have a vaccum leak somewhere because the relay/interlock valve worked last night. I fix one thing another stops.
Old Jan 28, 2009 | 06:09 PM
Alan 71's Avatar
Alan 71
Hi W,
Do you realize that in 1973 the service managers all got together and had the engineer who designed the wiper/headlight systems assasinated?
It's really neat when it works but it can drive you absolutely crazy!!!
Do you have the trouble shooting guide from Dr. R. ? It really helps.
Regards,
Alan
Old Jan 28, 2009 | 06:28 PM
72LS1Vette's Avatar
72LS1Vette
Pull the outer rubber bellows off the canister and make sure the seal hasn't popped off. My 72 hadn't been run in 10 years and the wiper door didn't work. I found that the seal had popped out and when I re-seated it the door worked fine. Miracles do happen.
Rick B.
Old Jan 28, 2009 | 07:01 PM
turbojet's Avatar
turbojet
I know you adjusted the wiper door actuator but this happened to me i checked it again and moved it up then it worked fine. If you can post some pics. Good Luck
Old Jan 31, 2009 | 02:12 PM
wallifishrmn
I adjusted the wiper actuator and the wiper arms and now it works. Thanks for all the help.
To 1971 Wiper Problem
