Steam Cleaner?
Old Jan 31, 2009 | 02:05 AM
Bowerss2's Avatar
Bowerss2
Default Steam Cleaner?
Hey all,
Has anyone used a steam cleaner to clean/ degrees the underside of their car/ engine
if so where would you get a hold of one?
Old Jan 31, 2009 | 08:55 AM
Alan 71's Avatar
Alan 71
I use to see garages with signs that said they steam cleaned engines. I don't see those anymore. Is it possible that pressurized steam from a true steam generator is hard on the rubber and electrical components?
Regards,
Alan
Old Jan 31, 2009 | 09:10 AM
dmaaero's Avatar
dmaaero
I have a little mini floor jack, i put it an a rain suit in the passenger floor an off to the car wash i go.
Old Jan 31, 2009 | 09:15 AM
Sebago Shark's Avatar
Sebago Shark
St. Jude Donor '09
I got a hot water faucet in my garage. That along with my pressure washer do a great job.
Old Jan 31, 2009 | 10:03 AM
70Yellowbird's Avatar
70Yellowbird
I use a small inexpensive McCulloch Steamer that I bought on the internet. It runs for about 45 minutes before needing a refill.
I've seen the same model at the local Harbor Freight store ... it's even cheaper if you use one of the 20% discount coupons that often come in their emails.
It's used mostly in combination with a degreasing spray ... works fine, but is very slow in getting the job done. I'm satisfied with the results.
Old Jan 31, 2009 | 10:26 AM
SIXFOOTER's Avatar
SIXFOOTER
I made a short nozzle for my pressure washer and a hose from the water heater on mine, clean as a whistle. I hung plastic from the walls above my cabinets and taped it to the floor to keep the spray off of everything. wear safety glasses and a disposable rain suit.
Old Jan 31, 2009 | 10:49 AM
682XLR8's Avatar
682XLR8
Hot water heater and a garden hose here, so if the part to be cleaned can be moved I can take it out to the driveway or backyard. Wear the aforementioned protective gear, and gloves, the water nozzle is going to get hot!
Old Jan 31, 2009 | 11:22 AM
Alan 71's Avatar
Alan 71
There's a big difference between pressurized hot water and pressurized steam. I think a pressure washer or car wash works great but I'd be concerned about steam. Steam is what you get when you open the radiator cap too soon... pretty dangerous.
Regards,
Alan
Old Jan 31, 2009 | 02:36 PM
OURSHARK's Avatar
OURSHARK
This method works fine.
Old Jan 31, 2009 | 03:40 PM
LIQUIDDRAGON's Avatar
LIQUIDDRAGON
ive used my steam cleaner for cleaning parts on my car for a few years now and i must say that it is the fastest and easiest method that i have found plus you dont get those nasty fumes from chemichals. here is a link to the newer version of the one that i have.
http://www.target.com/Shark-Ultra-St...cleaner&page=1
Old Aug 3, 2011 | 09:55 PM
69VetteFla's Avatar
69VetteFla
I was looking at the McCullogh steamer. Which model do you have and when you say it is very slow in getting the job done - how slow is very slow? Thanks
Old Aug 3, 2011 | 10:20 PM
wgarneau's Avatar
wgarneau
I've used a steam cleaner on car interiors. Works great - never had a problem.
Old Aug 3, 2011 | 10:30 PM
noonie's Avatar
noonie
Years ago I had a real "Steam Jenny" for cleaning heavy equipment etc. If you have oils and grease it works better than anything.
It used kerosene to heat, but only put out a few hundred psi vs a pressure cleaner than puts out thousands psi.
I think the max temp of the water was around 300°F.
Any eaquipment repair should be able to do it for you at a decent price.
Old Aug 3, 2011 | 11:13 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
I used a local steam cleaning place it cost me 50.0 to do the underside before we did the motor swap... it was nice and clean when they finished ..
Old Aug 3, 2011 | 11:48 PM
Clubby99's Avatar
Clubby99
http://sanjoseautosteamcleaning.com/...eam_clean.html
I've used this place in San Jose for the past 20 years. I get almost every "new" old car steam cleaned before working on it. They steam the top & bottom of the engine plus the chassis for about $200. Not cheap but worth it. Ten years ago, it cost $75 but now these companies have to pay $$$ enviromental fees. Most closed. Few exist anymore.
But well worth it. Most "steam cleaning" businesses actually use pressurized hot water and call it steam. This place has a giant boiler and uses real steam. Big difference. With real steam, your engine and chassis are spotless. Makes finding leaks easy. Plus your hands remain clean when working on the car.
Old Aug 3, 2011 | 11:59 PM
69VetteFla's Avatar
69VetteFla
That sounds like a smart move. I need to find a place like that by me.
Old Aug 4, 2011 | 12:12 AM
ptroxx's Avatar
ptroxx
Thats the place I used....50.00 2 yrs ago
To Steam Cleaner?
Old Aug 4, 2011 | 12:37 AM
Clubby99's Avatar
Clubby99
Looked familiar but thought you lived in Sacramento. I did it all. Top, bottom, and full chassis.
I think there is only one or two places in all of California.
Old Aug 4, 2011 | 11:31 AM
69VetteFla's Avatar
69VetteFla
No wonder I am having a hard time finding anyone down here. Not going to give up but if their are only 2 in all of CA we probably have 1/2 of one down here in FL. If anyone knows of a place down here in So Fla please let me know. Thanks
Old Aug 4, 2011 | 12:08 PM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
Be careful with a pressure washer. They can eat up old fiberglass in a heartbeat.
