differential crossmember
Old Jan 31, 2009 | 12:06 PM
temvette72's Avatar
temvette72
Default differential crossmember
Does the differential crossmember have a curve to it? I notice that mine has a pronounced arch from side to side. It curves up in the middle where the diff. mounts to it. Is this normal? I haven't noticed in pictures of the crossmember when it is out of the car.
temvette72
Old Jan 31, 2009 | 01:09 PM
GD70's Avatar
GD70
Should be straight. Here's how mine looks. Can't see the entire cross member, but looks straight. Maybe it was jacked up, or supported there for a length of time causing this.
Check some of the resto threads and you'll be able to see the entire frame.
Hope this helps.
Glenn
Old Jan 31, 2009 | 02:18 PM
Alan 71's Avatar
Alan 71
Hi T72,
I think you can see how straight it is compared to the frame cross member at this angle. I'd think it would take quite a bit of force to bend it since it's built as a box beam.
Regards,
Alan
Old Jan 31, 2009 | 04:07 PM
BritewhiteC3's Avatar
BritewhiteC3
Here's my 75 during a diff change
As Alan says notice how straight the crossmember is
Old Jan 31, 2009 | 04:37 PM
Gordonm's Avatar
Gordonm
If you are talking about the top bar you can see it is curved in this picture. I agree on the lower part being straight.
Old Jan 31, 2009 | 08:30 PM
temvette72's Avatar
temvette72
I think this last pic answers my question. It is curved across the top. That looks just like mine! Thanks to all!
Temvette72
To differential crossmember
