intake question
Old Feb 14, 2009 | 04:38 PM
DSA1's Avatar
DSA1
7th Gear
Default intake question
Need some info...just purchased intake manifold for my 71. What are rules for the casting date? Is it no more than 6 months prior to engine assembly date?(per NCRS guidelines). Thanks
Old Feb 14, 2009 | 04:45 PM
Alan 71's Avatar
Alan 71
Hi DSA,
If you're thinking of NCRS judging you're right about the six month window.
Regards,
Alan
Old Feb 14, 2009 | 06:25 PM
DSA1's Avatar
DSA1
7th Gear
Default intake
Thanks for clearing that up.
Old Feb 15, 2009 | 11:08 AM
Alan 71's Avatar
Alan 71
Hi D,
Since you're working towards getting your 71 back to stock perhaps you should consider buying the NCRS 70-72 CORVETTE TECHNICAL MANUAL & JUDGING GUIDE. I think you find it interesting and helpful. Check out the Store at the NCRS Site.
Regards,
Alan
Old Feb 16, 2009 | 08:55 AM
DSA1's Avatar
DSA1
7th Gear
Default intake
I have third edition---I see a fourth edition is now available. I had a conversation with a gentleman and he told me it was only a three month window on the date code. He said he received this info from a judge at a NCRS meet.
Old Feb 16, 2009 | 09:46 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by DSA1
...I had a conversation with a gentleman and he told me it was only a three month window on the date code....
6 months is acceptable; 3 months is better, and if you can get closer still, you're better off. The engine in my '68 was assembled on 4/9/68; intake manifold is dated the end of March. Time/build code is 4/20/68.
What's the time/build code for your car? There was a strike at St. Louis from mid-September through the end of November 1970 which could throw off numbers.
Old Feb 16, 2009 | 04:32 PM
Alan 71's Avatar
Alan 71
I'm sure the NCRS date guidelines are 6 months prior to production date.
Often MANY parts are MUCH closer than 6 months. Sometimes only a few days or weeks.
The intake manifold of my original owner 71, 350/270, (Jan 71 build) is dated H 27 0, (August 27, 1970). The vast majority of parts on the car have December and January dates. The manifold is the only date that seems odd.
Regards,
Alan
Old Feb 17, 2009 | 02:27 PM
DSA1's Avatar
DSA1
7th Gear
Default intake
Assembly for motor is April 21/body is May. Thanks
To intake question
