1978 vs 1982 Corvette
It's obviously spent some time outside if the bumpers look like that.
As for the pictures you've posted - first, the 78 has a rear bumper from an '80 to '82. A rear bumper for a 78 was rounded unless it was a pace car and even then the spoiler is bolted on. It was molded in starting with 1980.
The paint issue on the nose of the 82 is sort of normal. I really can't tell how bad the paint is on the entire car. Just for fun, price a paint job. If your dad is thinking of buying it and having it painted later he may be surprised at the cost of a paint job on one of these cars.
From the pictures, both cars look a little rough for the low miles. There can be problems with what the speedo says vs actual mileage...real easy to disconnect speedo. Ask for several (more than one) sources of documentation on the mileage.
The interiors seem a little worn for the low miles as well. Take your time and do a sniff test. Pull back the carpets and look for signs of moisture...also look for rust (search "birdcage" on this site for more info) By the way, new carpet, seats and door panel will set you back approx $2500 but it is an easy resto project done with a screwdriver and lots of time. You may think you could only replace the one seat or door panel that needs repaired but the colors never match so you'll end up doing the entire car
I could go on (the '82 has the wrong center caps, should be silver not black..the 78 has the wrong center caps, should be black, not silver...
) but in the end the cars a fair priced at approx $7K but you need to know what you are buying. Feel free to post up more pictures. Last thing, I think it's really neat that you are doing this with your dad
That said, I agree with the above that both interiors look pretty tired for 50K mileage cars IMO. Also, note that the '78 is missing the spare tire and tub. If your Father is interested in spare tire capability, that is an issue that should not be ignored. A new tub is about $250. I have been trying to find a decent one on e-bay, but they are either junk, or I "win" the auction only to have the seller bail out, so keep in mind that you are in for some bucks or some aggravation or both.
JU
I like the interior (Nicer Seats) in 82 and overdrive in the trans for better gas mileage. Crossfire is cool but it can be a pain in the butt if previous owner didn't maintain the vehicle. Fiberglass rear spring. The only thing I did not like about 82 was no manual trans option.
78 was also a nice year, again you pick
