Eastwoods Zinc Plating System
Old Feb 21, 2009 | 04:39 PM
NMT1957's Avatar
NMT1957
Default Eastwoods Zinc Plating System
Has anyone tried their zinc plating system? Id like to know what results you have had with it.
Old Feb 21, 2009 | 06:15 PM
Alan 71's Avatar
Alan 71
Hi NMT,
I've used the Eastwood system. It works well consdering the very small power (battery) it has. I use it to plate bolts and nuts.
Take a look at Casswell. Much larger and more capable systems at a higher price.
Regards,
Alan
PS: The Casswell system has been talked about on the NCRS Board.
Old Feb 21, 2009 | 06:37 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
All you need to do this at home is a zinc anode (Used on boats), an electrolyte solution, two wires and 6 volts of power. (Power supply, batteries, ect.).
Wire wheel or sand blast your part, and then use muratic acid as a cleaning solution before you plate. You might want to do a Google on How to and see what it turns up.
Willcox Inc.
Old Feb 21, 2009 | 06:57 PM
Duke94's Avatar
Duke94
I used it to plate a lot of parts on my 71'. Here is the hood latch. It probably wouldn't last 10 minutes in a salt spray environment but it has held up well on my summer only car. I bead blast all the parts before plating. I use a 3 Amp power supply instead of a flashlight battery.
Old Feb 21, 2009 | 07:07 PM
70454Convert's Avatar
70454Convert
I use the caswell system. Don't know how I'd do my resto without it.
after (this is with briightener and some ultrafine sanding before plating-makes the zinc look like chrome)
After
after (with yellow chromate)
Old Feb 21, 2009 | 09:52 PM
NMT1957's Avatar
NMT1957
Well I got mine delivered today and just had to go try it out tonight. It has worked great for the nuts and bolts. I didnt like polish they give you so I tried a few other things to get the dull appearance off. I used a brass wire brush, soft bristles, and it worked great. If I do the big parts, like the hood latch above, I will probably use the polish since it would leave a better finish Im sure. I should have asked this question before I ordered mine, I probably would have bought the bigger one from Casswell. Thanks for everyones input. now I have to figure out what bolts get what finish....
Old Feb 22, 2009 | 05:34 AM
hunt4cleanair's Avatar
hunt4cleanair
Hey Duke
No offense and it may be the photo quality but the latch looks more painted than plated. Is it just photo quality?
Old Feb 22, 2009 | 05:37 AM
hunt4cleanair
Yellow cromate is impressive...what size did you get?
Old Feb 22, 2009 | 06:39 AM
Droptop-Rob's Avatar
Droptop-Rob
I have used the Caswell Copy Cad 1.5 Gal system. I Just thought the kit looked more complete, it is a quality kit, I was pleased with the results. Good luck, as with painting it is all in the prep.
Rob
Old Feb 22, 2009 | 08:04 AM
Duke94's Avatar
Duke94
Originally Posted by hunt4cleanair
Hey Duke
Not painted.
Old Feb 22, 2009 | 10:02 AM
70454Convert
1.5 gallon with a 5 amp power supply.
Old Feb 22, 2009 | 10:44 AM
NMT1957's Avatar
NMT1957
I planned on ordering the 3 Gal Kit from Caswell but they are out of the 5 amp power supply. Also out of the 3 amp. I wonder how long it takes to get them in. Ill call and find out tomorrow.
Old Feb 22, 2009 | 02:57 PM
71coupe454's Avatar
71coupe454
Hey this good timing, I'm detailing under the hood, can we see some more pics of you guys plated parts and what your using?
Old Feb 23, 2009 | 05:23 AM
hunt4cleanair
For price difference looks like 5 amp is better investment. Be curious what amp size others are using
Old Feb 23, 2009 | 07:32 AM
Duke94's Avatar
Duke94
I used a 3 AMP with my Eastwood kit.
Old Feb 23, 2009 | 04:22 PM
71white's Avatar
71white
Willcox Inc.
What is the electrolyte solution??
Old Feb 24, 2009 | 11:27 AM
71white's Avatar
71white
Bump
To Eastwoods Zinc Plating System
