Tunnel insulation effectivenesss
Old Mar 14, 2009 | 06:29 AM
AWilson's Avatar
AWilson
Default Tunnel insulation effectivenesss
I plan on using a heat and sound barrier such as Dynamat under my carpet. My question is should I also replace the insulation that was under the car in the transmission tunnel? Or is this not effective and more for correctness than anything else.
I guess my real question is whats the best way to keep as much heat out of the passenger area?
Old Mar 14, 2009 | 09:34 AM
Emeightch's Avatar
Emeightch
I'm doing this now, a layer of Dynamat Extreme is down and I plan to put a layer of Reflectix (from Home Depot/Lowes) up front to try and block some of the engine heat coming in. As for the carpet pad, I'll probably have that too locally where you would step.
By the way, you will need 2 packs of the 36 sq foot dynamat if you plan to do the entire interior! Cheapest price is on Ebay.
Old Mar 14, 2009 | 11:03 AM
7T1vette's Avatar
7T1vette
Dynamat is "sound" insulation; Reflectix is "heat" insulation. Install what you need.
Old Mar 14, 2009 | 11:12 AM
vett us all's Avatar
vett us all
Is it a good idea to put reflectix down first, and then the dynamat?
Old Mar 14, 2009 | 11:19 AM
Theiskell's Avatar
Theiskell
??????That kinda defeats the purpose of the dynamat doesn’t it?
Old Mar 14, 2009 | 11:55 AM
vett us all
I don't know. I have never had sound heat up an interior of a car as far as I know. If dynamat will not deter heat, why not use both products? I am assuming that reflectix will help the heat issue, and the dynamat will help the noise issue. I am about to put the interior back in my vette, and want to do the right thing.
Old Mar 14, 2009 | 12:17 PM
Theiskell's Avatar
Theiskell
The Dynamat will be much more effective on the floor to dampen vibrations. Then install the insulation over the dynamat. That way both products can work the way they were designed.
Old Mar 14, 2009 | 12:22 PM
Theiskell's Avatar
Theiskell
When I read your first post I thought you were stating the order of how to install the two. Then I reread it and realized you were asking “how to” sorry.
Old Mar 14, 2009 | 12:36 PM
vett us all
No problem. You just cleared up my questions. I will insulate my interior just as you described. Thanks alot Lynn
Old Mar 14, 2009 | 12:54 PM
gator77's Avatar
gator77
Great info on the interior, what about the trans tunnel (under the car)? I've been wondering the same thing about both! Thanks!
Old Mar 14, 2009 | 01:41 PM
7T1vette's Avatar
7T1vette
An auto tranny has a separate heat shield that fits over the tranny main case and a foam "seal" the fits between the leading edge of that heat shield and the bottom of the floor pan. They are needed to effectively reduce tranny heat. Reflectix alone won't do that job; but Reflectix over the entire tunnel, in addition to those items, would be of significant benefit. Also, put it under the radio an up the inside of the firewall as far as you can conveniently reach.
Old Mar 14, 2009 | 06:36 PM
AWilson's Avatar
AWilson
I appreciate the info so far but I still need some clarification. In the tranny tunnel the car originally had some sort of insulation that attached to the body not the transmission. Is this what you are reffering to?
Old Mar 14, 2009 | 07:07 PM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
yes, keep the insulation in the tranny tunnel and add the reflectix to the interior also.
Old Mar 14, 2009 | 10:11 PM
7T1vette's Avatar
7T1vette
I think the only insulation on top of the tranny tunnel was some pieces of that thick jute padding. That stuff isn't very effective. I'd pitch it, if you're going to install Reflectix over the entire tunnel area.
Old Mar 14, 2009 | 10:47 PM
john roth's Avatar
john roth
I think that collar you are referring to sits on the top front of the transmission and redirects the hot air from the engine bay down and away from the cockpit floor. I bought one and will be installing it. They're not expensive and were a good idea in 1969 ??
Old Mar 15, 2009 | 12:37 AM
gator77's Avatar
gator77
My '75 had a foil covered pad in the trans tunnel (underneath the body) which I was planning to replace, and after reading these replies I will install the Dynamat and Reflectix in the interior
Old Mar 15, 2009 | 05:05 AM
harrin's Avatar
harrin
I did both, and would recommed that to you as well
To Tunnel insulation effectivenesss
Old Mar 15, 2009 | 05:19 PM
ksbunting's Avatar
ksbunting
Put the original heat shield inside the transmission tunnel under the body and attache it to the clips that are there.
This provides additional insulation between the trnasmission and the body and will make it that much easier for your Dynomat and Reflectix to do its job.
You will likely have to drop your tranny to get the preformed aluminum & fiberglass tunnel insulation properly fitted and onto the retaining clips that are mounted under the body inside the transmission tunnel. Careful, they can be sharp.
That's what I had to do on my 68
Kurt
Old Mar 16, 2009 | 09:07 PM
tnovot's Avatar
tnovot
I am going to disagree with others and say yes. It would seem to me that putting down Dynamat under the heat barrier would allow heat through the Dynamat to the point that when it reaches the Reflectix, heat would be radiated back through the sound barrier and would cause it to rise in temp. Makes no sense not to put down heat barrier first to keep the heat farther away from the carpet. Can't see any reason why the sound barrier wouldn't work in either location
I just finished today repairing seats and installing Reflectix only. With 3" true duals with Magnaflows in a convertible, sound coming through the floor isn't an issue.
Terry
Old Mar 16, 2009 | 11:22 PM
Theiskell's Avatar
Theiskell
Terry
The dynamat works by stopping or deadening the sound vibrations that run through the body of the car. If you put down insulation first the vibrations will still travel freely under the dynamat. The dynamat isn’t a heat insulator so it doesn’t reflect heat back up enough to cause a problem. I used dynamat then insulation over the top in my car it’s cool and quiet. It was a huge improvement over stock.
