Erratic steering
Old Mar 20, 2009 | 10:40 PM
GLCLEVELAND's Avatar
GLCLEVELAND
Cruising
Default Erratic steering
On my 81 , I noticed lately when its cold , for the first 1/2 mile or so the car wanders left and right and darts slightly to the left , but after that it steers perfect except every now and then (like every few days)the car will dart slightly to the right without turning the steering wheel . All the tie rods and joints seem tight . Is this a steering valve problem ?
Old Mar 20, 2009 | 11:42 PM
72LS1Vette's Avatar
72LS1Vette
You are going to have to examine the whole suspension and steering system to look for the problem. It could be the steering box, steering ram binding, alignment, or it could be something in the rear suspension. My 72 used to head for the left lane, even if it was oncoming traffic, every time I hit the gas hard. I found that the left differential yoke had no C-clip and could move in and out of the differential. Combined with worn trailing arm bushings, that was a big contributor to the handling problem.
If you can post some pics of your front and rear suspension maybe someone can help identify the problem.
Rick B.
Old Mar 21, 2009 | 12:16 AM
onaqwst's Avatar
onaqwst
rag joint or maybe a motor mount
Old Mar 21, 2009 | 12:43 AM
PeteZO6's Avatar
PeteZO6
Worn ball joints and/or tie-rod ends. Any slop in the many pieces of the suspension and steering systems will cause this. Like 72LS1Vette said, anything in the suspension or steering can cause problems like you describe.
Old Mar 21, 2009 | 01:28 AM
SIXFOOTER's Avatar
SIXFOOTER
That sounds like the steering control valve is about to die. rebuild it or get a new one. Mine came close to putting me in the wall on a quick lane change a couple times. New vlave and no problem. You might be able to adjust it, but sounds like its toast.
Old Mar 21, 2009 | 10:14 AM
GLCLEVELAND
Cruising
Thanks everyone , It seems though that if it was a suspension/bushing (i'm sure that they need attention) problem and/or tie rod/ball joint problem it would drive that way all the time . But , most of the time it drives perfect . All of the tie rods/steering joints are tight . Thanks again for the info everyone , you guys are great !
Old Mar 21, 2009 | 10:32 AM
bj1k's Avatar
bj1k
Old Mar 22, 2009 | 12:46 AM
RIJVETTES's Avatar
RIJVETTES
And then get a good alignment. I did both of these on my 80 about 2 months ago..... nite n day difference. Damn, I have control and can drive straight!
Old Mar 22, 2009 | 06:54 AM
7T1vette's Avatar
7T1vette
Have you checked the power steering fluid level lately? Sounds like low fluid to me...
Old Mar 23, 2009 | 01:37 PM
GLCLEVELAND
Cruising
Fluid level is ok , I learned a long time ago to check the simple things first , thanks for your input
To Erratic steering
