Engine Stand Pick-up
Old Mar 21, 2009 | 04:23 AM
hunt4cleanair's Avatar
hunt4cleanair
Default Engine Stand Pick-up
Picked up a $100 engine stand used at a hot rod meet for $20. Not bad shape some rust but worthy of a sandblast and paint. Just tickled pink. It's one of those tri-pod types with a plate and adjusting bolts.
My guess
• 3 Piece Caster Wheels - 2 stationary - 1 Swivel
• T-shape support and balance
• Sturdy Tubular Framing 1000lbs. capacity
• Engine will rotate 360 degrees
• Heavy duty
Old Mar 21, 2009 | 09:04 AM
Alan 71's Avatar
Alan 71
I found the 3 wheel stand wanted to tip over forward. It made me nervous enough to buy a 4 wheel version.
Be careful!
Regards,
Alan
Old Mar 21, 2009 | 09:33 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I use the a 3 wheel stand for storage of my old 350, when working on high dollar motor I use the 4 wheel type, if it is a big block then the 4 wheel type should be used. You can tip the 3 wheel ones over and they just don't seem safe or stable to me.
Old Mar 21, 2009 | 04:49 PM
hunt4cleanair
Thanks for the tips...and here I thought I got a good deal.
Old Mar 21, 2009 | 04:56 PM
rayluka's Avatar
rayluka
Id say its a good deal, just be cautious
Old Mar 21, 2009 | 08:33 PM
71coupe454's Avatar
71coupe454
Thats what I have, carefull rolling it in the direction of the single wheel, ok going the other direction
Old Mar 21, 2009 | 09:13 PM
QuicheLorraine's Avatar
QuicheLorraine
Yeppers esp with a rat motor. I was working on a 396 one day when a fellow tech tried to move the motor to pull a car in the bay I was using. You guessed it: It tipped over on him & he almost lost a foot.
Old Mar 21, 2009 | 10:08 PM
stpman's Avatar
stpman
I have 3 3 wheel stands that I made myself, haven't had a problem yet but they are made from 3" sq tube and has a wide stance.
Steve
To Engine Stand Pick-up
