9 leaf rear spring
Old Mar 27, 2009 | 02:45 PM
razman's Avatar
razman
Default 9 leaf rear spring
does anyone have a decent pic of a 9leaf rear spring assembled? i took mine apart to restore, and re-assembled it, and now i'm not 100% sure that i have it back together correctly!
Old Mar 27, 2009 | 03:44 PM
Sebago Shark's Avatar
Sebago Shark
St. Jude Donor '09
This is a replacement a PO had put on my '78. Don't know how original it is. Took it off for a composite. Can get closer detail if it helps.
Old Mar 27, 2009 | 04:00 PM
razman's Avatar
razman
that helps a little, thanks. my question is really this: do the top 3 shorter leafs go in with the ends flipping upward like the rest of the leafs, or are they turned over the other way? i'm pretty sure that all of the leafs go in the same way, with the ends turning up, but for some (stupid) reason i re-assembled mine top 3 shortest leafs the opposite way.......
also, aren't those 2 straps on your leaf spring only for shipping puposes?? thanks again, rick
Old Mar 27, 2009 | 04:04 PM
Alan 71's Avatar
Alan 71
Hi RM,
Here's the original 9 leaf on my 71.
Regards,
Alan
Old Mar 27, 2009 | 04:26 PM
Grumpy 427's Avatar
Grumpy 427
Clamping leaf springs make them stiffer.in drag racing on a regular leaf spring car, you would clamp the front of the spring and leave the back un clamped. the car would launch better and avoid spring wrap up. Those clamps need to be on your spring.
Old Mar 27, 2009 | 05:11 PM
Sebago Shark
St. Jude Donor '09
All the curled ends are the same way. I would think so they slide easier with movement.
Straps don't appear to be for shipping, pretty heavy with thick rubber on top, but, again, it's an aftermarket spring, so I don't know if they should be there or not.
Alan, Really nice looking work back there.
Old Mar 27, 2009 | 05:16 PM
razman's Avatar
razman
alan, thanks a bunch! that pic is exactly what i needed, and just as i thought, i put the top three leafs in upside down. no problem, quick fix! thanks again, rick
To 9 leaf rear spring
