Front end Shutter
Old Mar 28, 2009 | 07:42 AM
imariver's Avatar
imariver
Default Front end Shutter
Ok so I'm making a right turn from an intersection and I hit a minor rough spot in the road and all of a sudden the front end starts to shake very violenty. By this time, I had just come out of the turn and was doing about 25/30 mph. The steering wheel was shaking so bad I had to pull over and stop. I actually thought a tie rod came loose, it was that bad. Drove the rest of the way home without any problem. Anyone have any thoughts on this? The entire suspension is OEM and otherwise It handles and steers ok. Got it up on blocks now, and can't see anything wrong at all.
Old Mar 28, 2009 | 09:51 PM
my 76 ray's Avatar
my 76 ray
If you figure it out please let me know. I've had the same problem but haven't had time to really dig into it.
Old Mar 28, 2009 | 09:57 PM
rayluka's Avatar
rayluka
Where you on a slick or sandy road? My only thought...and its a stretch...that the pothole you hit just plain shook the whole suspension on your car. If the tires werent stable it would extend the action.. A bit of a stretch but I'm just guessing here
Old Mar 28, 2009 | 11:50 PM
OMF's Avatar
OMF
I encountered this once before on a Monza modified for IMCA racing.The car had 8"rims on the front with a minimal backspacing,so this made the front track quite wide.Once in a while the same thing that happened to you would happen to this car. The fix was spacers that gave the front end more negative camber so that the outside edge of the tire was only used under considerable cornering forces.
My suggestion is to check your camber and make sure its within specs,or slightly more negative camber if you have a tendancy to corner faster than most.
Old Mar 29, 2009 | 09:12 AM
imariver's Avatar
imariver
I have known some front-wheel-drive vehicles with CV joints to do this, (wobble violently) during a hard turn, but never a double wish-bone suspension! If this is indicative of worn out components and out-of-spec alignment........ this baby is going to stay on blocks for a long time untill I win the lottery
I think Mr. Shea might be shedding some light on this soon.
Thanks everyone for the info.
Steve
Old Mar 29, 2009 | 12:05 PM
71coupe454's Avatar
71coupe454
Have you checked all the front end parts for any play?
Old Mar 29, 2009 | 02:51 PM
imariver's Avatar
imariver
Yes I have checked the front and rear components and didn't see anything worth pointing the finger at. Could this have been a case of "wheel-hop" ??
Old Mar 29, 2009 | 02:57 PM
wer2xu's Avatar
wer2xu
wheel hop is a solid axle problem rear wheels hop under hard braking...did you check your idler arm, and the other power steering components....if you have ps.
Old Mar 29, 2009 | 02:59 PM
wills670's Avatar
wills670
Does it have power steering? If so might be a problem with the control valve?
Old Mar 29, 2009 | 04:19 PM
dannyman's Avatar
dannyman
If you can't find any signs of excessive play or wear, then I'd run it in for an alignment.
Old Mar 30, 2009 | 05:57 PM
imariver's Avatar
imariver
Yes, it does have power steering. However I am not familar with this type of control valve to blame it. I'm suprised there isn't more on this subject, on this forum.
Old Mar 30, 2009 | 06:10 PM
1nicecorvette's Avatar
1nicecorvette
how bout a broken spring?
Old Mar 30, 2009 | 11:20 PM
dariopop's Avatar
dariopop
Had the same problem, its your idler arm , easy fix ,about a $25.00 and 15 mins or less. Put a new one in mine and no more shake or shimmy when hitting a pot hole
To Front end Shutter
