How to get Motivated???
You'll end up with a bigger "to-do" list if you let it sit.
Enjoy it!
if it's drivable the take it for a cruise, if not then i would start with the smaller projects that make you feel like you've accomplished something.
for example: the lights on the passenger side mirrored visor rattled incredibly badly. 4 small pieces of electrical tape (black interior) is a good "quick fix" that didn't cost anything, but at the same time i felt like i had accomplished something.
I tried to do one thing every day that I was home on it over the last couple years even if it is just cleaning a part, shooting some paint or ordering some parts. It doesn't have to be big, but just do something. Just like exercising you don't have to kill yourself, just do something every day and it adds up and becomes part of your routine.
Best to sit down and write down your goals and objectives for the Corvette.
Break down the goals into individual projects, maybe 6 or 8 different projects.
Then do the research into the cost of materials for each project.
Organize the projects into logical order. For example if you are recovering the seats you might as well replace the worn carpet when the seats are out.
Then order parts for the projects you decide to tackle, set aside a weekend.
An important consideration, estimate the amount of time it will take do complete each individual project, whatever number you come up with you should double. Example: If you think 5 hours to replace carpet you should plan for 10 hours.
Take your time and do each project correctly and when your done with each project you will have accomplished something.
Any project that you feel is above your ability you should seek help or pay a professional.
Problem most people have getting started is that they look at the entire project and it seems overwhelming. Break it down and go to work!
Good Luck with your project management,
Douglas in Green Bay
This is probably the best advice I've seen posted. double the time is accurate. w/o a list, you'll get lost, don't be surprised if it grows instead of shrinks as you get into it. I like stageing the parts and starting with the most difficult job, then the next most difficult,, etc. I did this because the more difficult jobs are usually the ones that keep the car from being drivable. Once you get it drivable, you can judge what you want to tackle next. This forum is a great resource for parts that work, and all the little tricks that only someone who has done the job can tell you.
Get Started!!! The Best of Corvette for Corvette Enthusiasts
Make friends and get some help working on it!
I'm sure any body on here would be willing to help for a couple beers!
Once you get started that way, you won't want to stop working on it!
1.) Write down how you would like to use the car; car shows, cruises, just FUN driving, all of the above. You need to know what you intend to do with it.
2.) Write down a description of how the car is configured when you are done with restorations>> [stock, lightly modded, heavily modded, full custom...]
3.) List the areas of the car that need work to reach your final goal for it. Prioritize that list by the importance of getting that work done. The usual order of priority is: SAFETY ITEMS (brakes, suspension, lighting); FUNCTIONAL ITEMS (engine, engine accessories A/C/heat); OPERATIONAL STUFF (windows, doors, wipers, radio, etc.); APPEARANCE ITEMS (paint, interior, wheels).
4.) Make detail lists of each parcel of work and in what order you will do it. Note: if you plan on painting the car, DO NOT finish the interior until the painting is done...or you will be doing a lot of work over again.
This might be classified as "busy work"...but if you can't even do this, maybe the purchase of your car was more of a "feel-good" move; kinda like eating a quart of ice cream when you get depressed. If making these lists and thinking about the car's future doesn't get you inspired....sell it. Good luck.
Work has been a beast this week though, not to mention either going to or coming home with a migraine that has it's own heartbeat.
That said, I liked the suggestion to take the car out. I think that would get me fired up, however I took it out a couple months ago on a nice day, and now the speedo needle is laying in the bottom of the guage, and the buzzing noise coming from the cable is beyond the point where I could enjoy driving it. Not to mention it was an incredible downer, but I talked about that on another post.
Anybody know a simple procedure for disconnecting the cable without diassembling the dash? I'd be happy to drive it around town with the speedo or the tach working, just taking it easy.
Here is the only pic. I have but it should give you a good idea of where to undo the cable. Besure to tie up the cable where it won't come in contact with something and damage it.
Problem is, I just can't get motivated to get started. The car is still covered up in the garage. (thank GOD the cat moved back to the neighbors from whence it came), so no issues there.
I don't know why I feel this way. I'm not lazy, in fact I've been working on one house/yard project after another. Just when it comes to getting cranking on this Vette, I would rather leave it alone.
Beautiful to look at though- -
Sell it to me......
(good luck and get goin
