How to get Motivated???
Problem is, I just can't get motivated to get started. The car is still covered up in the garage. (thank GOD the cat moved back to the neighbors from whence it came), so no issues there.
I don't know why I feel this way. I'm not lazy, in fact I've been working on one house/yard project after another. Just when it comes to getting cranking on this Vette, I would rather leave it alone.
Beautiful to look at though- -
Good luck.
I LIKE PROJECTS, BUT SOMETIMES THERE'S NOTHING LIKE GOING FOR A RIDE AND JUST ENJOYING.
I'M SURE YOU'LL FIND YOU SWEETSPOT.
BILL SR
Best to sit down and write down your goals and objectives for the Corvette.
Break down the goals into individual projects, maybe 6 or 8 different projects.
Then do the research into the cost of materials for each project.
Organize the projects into logical order. For example if you are recovering the seats you might as well replace the worn carpet when the seats are out.
Then order parts for the projects you decide to tackle, set aside a weekend.
An important consideration, estimate the amount of time it will take do complete each individual project, whatever number you come up with you should double. Example: If you think 5 hours to replace carpet you should plan for 10 hours.
Take your time and do each project correctly and when your done with each project you will have accomplished something.
Any project that you feel is above your ability you should seek help or pay a professional.
Problem most people have getting started is that they look at the entire project and it seems overwhelming. Break it down and go to work!
Good Luck with your project management,
Douglas in Green Bay
Do you have interior leaks? If not, rest assured you have 90% of the project already accomplished!!!
I've had my '81 for almost two years now and STILL can't chase down a nasty water leak on the passenger side! If we get an inch of rain, I get an inch of water! That has been the "project stopper" for me. I've bought most of the items I need for the interior restoration and will go "***** to the wall" to complete it - if I could only find the leak. Until then, no interior work.
If you have a dry interior - GET GOING! List all the work you need to do and start with the easiest. You'd be surprised at how gaining confidence one task at a time is going to help!
Good luck! ...Alan K.
Spring is here now. Did you buy the parts you need?
Lay them out on the floor arranged as if in the Vette. Imagine it all installed and looking awesome!
Look at some of the restoration threads here and you'll see that it's not that huge a job and you'll see results Immediately!
Go have a beer and sit back and admire your work.
Post a few pics for us so we can see what you need to do.
Glenn
