Is it a "tempature sending unit"
Old Apr 25, 2009 | 04:11 PM
phclub's Avatar
phclub
New England Events Coordinator
Default Is it a "tempature sending unit"
Just need to know, on the driver side of the 70 SB, I assume the unit near the front is the "temp sending unit", is this correct? And what is the unit on the passenger side (near the rear) for? Thanks for your input.
Old Apr 25, 2009 | 04:37 PM
CCrane65's Avatar
CCrane65
The one on the passenger side is a temperature sensor for the transmission controlled spark system. Provides information about whether the engine temp is below 82 degrees or above 230 degrees.
cc
Old Apr 25, 2009 | 05:33 PM
dennis's Avatar
dennis
The one in the RH head is a 3-way switch for the TCS solenoid (closed with a cold engine to provide manifold vacuum to the distributor, open in the normal operating temp range so the transmission controls the distributor vacuum, and closed if the engine is overheating to again provide manifold vacuum to the distributor). Completely different sending units.
Old Apr 25, 2009 | 05:51 PM
Alan 71's Avatar
Alan 71
Hi PHC,
No one actually said it... you're correct, the one on the driver's side IS the sender for the temperature gauge.
Regards,
Alan
Old May 1, 2009 | 09:29 AM
phclub's Avatar
phclub
Thanks Dennis, another question the TCS unit, is that the unit that sits on the manifold with three hoses leading off? I have this removed, what effect does not having this unit have on engine performance? Cheers,
Old May 1, 2009 | 11:56 AM
dennis's Avatar
dennis
Assuming your now have a direct vacuum connection from the front passenger side port of the carb to the distributor vacuum advance can.......improved preformance, smoother idle, all things being equal
Old May 2, 2009 | 08:06 AM
phclub's Avatar
phclub
I do, thanks for the quick reply!
Old May 2, 2009 | 10:03 AM
GD70's Avatar
GD70
TCS was essentially an early emissions device from what I've read.
To Is it a "tempature sending unit"
