I am ready to replace the antifreeze and some hoses in the 70/SB with an aluminum rad. I know that the aluminum rad required a special rad cap to eliminate chemical reaction with the rad. Do I need to use a special thermostat to avoid chemical action with the aluminum rad? any help would be appreciated!
Aluminum sometimes corodes when coming in contact with unfinished steel. In this circumstance you don't have anything to worry about because the thermostat does not come in contact with the radiator.
It's called a sacrifical anode. We had one in our diesel Fork lift that
had an exhaust scrubber system(It was for use in flammable areas).
Instead of the radiator corroding, the anode is "eaten" away.
Hope this helps.
CHEERS
GAV
In all seriousness, there was somebody that was pawning off rad caps with a sacrificial anodes for C2/C3 Corvettes using the standard scare tactics that 'it would prevent bad things from happening'. He was predicting total failure of cooling systems within months if his widget was not used.
The guy sort of went away when we pointed out all the 30 and 40 year old Corvettes with original radiators- and no sacrificial anode.
BTW- if you have an aluminum rad, is the cap mounted on the rad itself or the expansion tank?
A decent boat supply will have an assortment of screw in zincs with brass hex head that you can screw in your rad drain, tstat housing, block drain etc. Available in 1/8", 1/4", 1/2", 3/4" NPT etc. with an zinc about 3" long.
Less than $3.00 each.
If you're concerned, use them, can't hurt.
So now there's going to be a new myth that Corvettes suffer from galvanic corrosion?
You said "new"
I said "old"
Nothing being perpetuated. It's just another old debate that probably will never be conclusively resolved.
I personally don't use zincs other than marine, but I do add extra grounds and change coolant yearly. Nonetheless, if used, zincs will be sacrificed first whether it's galvanic or stray electrical.
All the auto manufacturers have issued TSB's for the problem and here is a "magic" quote from a GM bulletin
ACDelco service bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer." They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely.
From SERVICE BULLETIN 04D-J-051
3. Verify that no electrolysis is present in the cooling system. Electrolysis is the presence of "high" current circulating through the coolant. When coolant inhibitors are depleted, this level is usually higher than what is found in a normal system. Therefore, the electrolysis test should be performed before and after the system has been repaired to provide a basis for additional repair.
Again, if the OP is really worried about "chemical action" then he can use them. And remember that the coolant itself becomes the conductor and the dissimilar metals need not touch directly.
Anybody can find TSBs on just about any subject to supposedly prove any motherhood point they want. The excerpt you have quoted is as generic as it gets and can be interpreted to suggest the world as we know it is coming to an end. Why not post the remainder of the same paragraph of the TSB:
Use a digital volt meter set to 12 volts. Attach one test lead to the negative battery post and insert the other test lead into the radiator coolant, making sure the lead does not touch the filler neck or core. Any voltage reading over 0.3 volts indicates that stray current is finding its way into the coolant. Electrolysis is an intermittent condition that often occurs when a device or accessory that is mounted to the radiator is energized. This type of current could be caused from a poorly grounded cooling fan or some other accessory, and can be checked by watching the volt meter and turning on and off various accessories or by engaging the starter motor.
So the relevance of this TSB to a 1970 Corvette is about zero.
The OP asked a straightforward question regarding the need for a special thermostat to avoid galvanic action, not electrolysis. There is no special thermostat because there is no genuine need. There's a world of difference between 'need' and doing things 'just cause it makes me feel good'
