I was told yesterday that putting a car up on jack stands for our 5 - 6 month winter up here is "Bad" for the suspension. I've been doing this to all my summer cars, for years ??????????????
Ever go to your local Race track ? Well the first thing they do is put the car up on stand jacks (after they come in from hot laps or anything).Asked why one time, the dude said it takes the pressure off the frame & shocks and suspension. I keep using the stands.
If you use jack stands on the 'side' frame rails only, the whole weight of the front end is hanging on the front frame/birdcage. If there is any weakness in there at all (rust, etc.), it could do some damage. Just come up with a way to take some of that hanging load off the front when you store it. [i.e. another jack stand/wood block under the front cross support]
Letting the suspension hang will twist the suspension bushings into an extreme position that they're not designed to handle for long periods.
The tire flat spot idea is either false (I've never had such a thing) or can be overcome byu puishing the car a few feet forward and back every now and then.
The stress on springs and frame myth is pure BS. What do you do with your daily driver?
Flat spots go back many years (1950s) to the era of nylon-belted bias-ply tires. I lived in the Yukon at that time and with the cold of winter tires did develop flat spots overnight. These disappeared after a few minutes of driving.
I do not use jack stands October to April storage time.
What are you "protecting" by putting it on stands?
I have been to several race shops, and the only cars stored on stands or lifts were the ones that did not have wheels on them.
[QUOTE=Mike Ward;1570026864]Letting the suspension hang will twist the suspension bushings into an extreme position that they're not designed to handle for long periods.
I don't doubt what you are saying but I can't visualize which bushings or how they would be stressed
i read doing this will cause flat spots on the wheel bearings. not a good i dea. if your worried about tires just roll car a foot every couple weeks or so.
I would worry about tweeking the frame by having it sit on stands that long. As we know, the frames on these cars do crack and bend. Especially if there are rust issues.
The easiest example to visualize is the rubber bushing assembly at the front rear of a trailing arm. The outer metal sleeve is rigidly mounted in the trailing arm itself. The inner metal sleeve is prevented from rotating by the nut and bolt that squeezes the frame pocket and shims tightly together.
Both the inner and outer sleeves are bonded permanently to the rubber part of the bushing. So- how is it possible for the trailing arm to move up and down? Simple, the rubber bushing distorts by being 'twisted' away from it's natural position.
No conventional suspension bushing is designed to stay at maximum deflection for extended periods.
I ran across something similar when researching front swaybar bushings. I ordered a poly pair just to see how they perform but was puzzled by the need for lubrication although some have stated that is for noise reduction. (They have grease fittings.) But I believe there is more.
The stock rubber bushings grip the bar very tightly and when movement is experienced they actually twist or distort. There might be a similar effect by letting the front wheels hang on jackstands. The poly bushings are much harder and not prone to twist. Instead they rotate on the bar via the lube. Some say this lack of distortion provides a more "solid" feel in the steering. This may be hype but I should have the units this coming week and give them a try.
Your analysis of the poly wanna cracker bushings is correct Paul, that's why I specified 'conventional suspension bushing' in my response. The poly type actually slide back and forth over the mating metal components giving off the famous squeaks.
When I have mine up, which usually seems to be 3-4 months at a shot these days, I usually slide a 3rd pair of jack stands in front, right about where the exhaust pipes are coming down, where the frame curves inward to the center of the car.
That helps to alleviate any hanging stresses the front end might be seeing.
