Engine Leveler
Old May 18, 2009 | 02:25 PM
Fishndude's Avatar
Fishndude
Default Engine Leveler
My new motor and Trans are ready to be installed and I will probably end up doing this by myself.. Since I'm installing the Motor/Trans together this time, will I need a engine leveler to aid in tipping the Trans tail in first? I'm renting a cherry picker and just want to make sure I have everything I'm gonna need and make the job as easy as possible for myself... The cherry picker just has a hook on it..
Thanks!
Old May 18, 2009 | 04:21 PM
justaguy10825's Avatar
justaguy10825
I used a "Oberg Tilt Lift" that I had bought several years back... It had no problem lifting & tilting the 350/350 engine/trans combo...
http://www.thestricklincompanies.com...7701c6edf74b53
Old May 18, 2009 | 04:23 PM
Bronze76's Avatar
Bronze76
The engine levelers do work nice. Can you rent that too? A small wooden dolly or piece of plywood with wheels also helps to pivot the tranny into place. You would place the dolly under the transmission hump and then lower the engine/trans assembly so the tailshaft rests on the dolly and guides itself in.
Last time I did this myself, I purchased 2 small dollies from Harbor Freight tools. The first one kept the tailshaft off the floor, the second rested under the trans pan as I got closer. The dollies had some sort of carpet on them, so they gripped pretty well.
I normally remove the distributor when I install the engine. They can get in the way and even be damaged if you slip up a bit. It's best to prime the engine before you start it up anyway, so you might as well leave the distributor out just to be safe.
If you are doing headers....you may want to bolt them in before you lower the engine that last inch or so. It's MUCH easier that way.
Just some ideas. Nice looking engine you have there.
Old May 18, 2009 | 05:19 PM
MakoShark72's Avatar
MakoShark72
Abso-Freakin-Lutely!!! Although it can be done without a leveler, it will be WORLDS easier with one. I installed my engine/transmission assembly BY MYSELF easily with the leveler, in less than an hour! And still found time to take all these pictures....
Remove the distributor, pad surrounding areas with old towels, and I used a wooden dowel (closet rod) to shove the engine rearward to its final resting place. Also, almost forgot..I had my radiator out, and that makes things much easier, but not required...
The leveler was about $30 at Harbor Freight... Money well spent.
Old May 18, 2009 | 06:20 PM
Fishndude's Avatar
Fishndude
WOW, ask and you shall recieve.. Nice detailed photos!!! I see you didnt have your water pump or puley on either so it will surley be a tight squeeze for me but I have 2 full days to do it. I was really hoping I wouldnt have to pull the dist or radiator. And based on all the comments, a leveler seems likle the ticket.. The rental shop doesnt have any but its no big deal to buy one, since they are under $50 anyways.
Old May 18, 2009 | 06:31 PM
MakoShark72
The pulleys..I dont know? The distributor FOR SURE. At the tilt angle there is a great chance it will contact the top of the firewall. I was lucky as I was swapping in a ZZ4 and 2004R transmission. I had removed radiator, etc to clean up the engine bay. For me it was pretty easy.
Good luck!
Old May 18, 2009 | 06:37 PM
Fishndude's Avatar
Fishndude
Good luck!
I was planning on putting my front end up on ramps to give me more clearance for dropping/tilting it more downward and then tilting it back straight and working the trans into the tunnel at the same time.. There is no way Im gonna clear things with just a slight angle.. I drained my trans fluid so loosing fluid is not an issue.
By the way, nice Porsche!!! I almost bought a 911 instead of this Vette.. Matter of fact, I still wouldnt mind having one too.
Old May 18, 2009 | 07:04 PM
MakoShark72
I removed the front tires and lowered the car all the way down to make it easier to clear the fender. Your cherry picker may be limited in height. You can always raise the car after the engine is hanging over the engine bay. I was nervous swinging all that motor over all that fiberglass. The 911SC is a '79.
Old May 18, 2009 | 09:29 PM
7T1vette's Avatar
7T1vette
If you have a leveler and a strong back, you can put the engine/tranny in by yourself....but what fun would that be???? Nobody to cuss with? : No one to drink beer with? No one to complain to when things go wrong? I just can't imagine the pure boredom of doing that alone. {just funnin'...hope it goes well}
Old May 18, 2009 | 09:39 PM
Jeffery73's Avatar
Jeffery73
St. Jude Donor '08-'09-'10-'11-'12-'13
I have the same leveler as in the pictures. I did mine myself and it wasn't too bad. Of course it would have been more fun and easier with another person or two to help but all my friends are married with kids. We all know how that goes....
Old May 18, 2009 | 10:58 PM
Theiskell's Avatar
Theiskell
If you use the leveler be sure to put the crank handle toward the front of the motor. When you just about have it set in place you will find that the arm hits the fire wall if it’s in the rear. Yeah go ahead and laugh, I threw wrenches and anything I could get my hands on.
Old May 25, 2009 | 07:35 AM
Fishndude's Avatar
Fishndude
Thanks everyone!!
I couldnt of done it without the engine leveler.. It went in as smmoth as silk... I fired the new motor up yesterday and dang does this thing sound mean.. It actually sounds better than my previous 73 Camaro that ran 10.80's...
To Engine Leveler
