purtronix electronic ignition
Old May 19, 2009 | 02:46 PM
andycw's Avatar
andycw
Default purtronix electronic ignition
Anybody out there try this? Did it make a difference?
andy
Old May 19, 2009 | 02:57 PM
Jeff_Keryk's Avatar
Jeff_Keryk
I use the Ignitor on my 68 L36 to trigger the MSD box. I use the Ignitor 2 (I think) and coil on my verrry original 65 442. I am thinking of buying a 64 to 67 El Camino. If I do, I will get another Pertronix setup.
Did it make a difference? Well, there is nothing wrong with points. I believe it smoothed out the idle somewhat, but that could be due to the age of the points. I don't think there are any more cars built with points.
Others will chime in with their experiences...
Old May 19, 2009 | 03:20 PM
andycw's Avatar
andycw
Default which one
I was looking on the purtronix web site and noticed there are 2 types of the igniter II available for a V8. One is for a dual point the other is standard. How can I tell if I have dual point or not. I have a 350.
Old May 19, 2009 | 03:26 PM
Mike Ward's Avatar
Mike Ward
No upgraded ignition or conversion will make a difference in performance if that's what you're asking. The early Pertronics units had a horrible reliability record, the latest ones seem to be OK.
The only thing they achieve is eliminating occasional adjustment or replacements of the points. I doubt very much if you have dual points in your existing distributor.
Old May 19, 2009 | 03:28 PM
andycw's Avatar
andycw
Default thanks Mike
I apologize for my ignorance, thanks for the input.
andy
Old May 19, 2009 | 04:00 PM
Skip Burney's Avatar
Skip Burney
I guess I am the exception to the rule here I built a 390 Ford to put in my 65 pickup and put a Pertronix in it 10 years ago and it is still going strong. No more setting points to trouble starting. I am going to put one in my wifes 72 Vette soon.
Old May 19, 2009 | 08:24 PM
djrammer's Avatar
djrammer
I just put the kit in my car Saturday. I've noticed it starts better. No more points. Should be better on plugs also.
Dewey
Old May 20, 2009 | 06:30 PM
RagTop69's Avatar
RagTop69
I've had Ignitors installed in two 69 Mustangs since 1995 and 1998 respectively. I realize that this is anecdotal, but mine have been as dependable as can be in that 14 year and 11 year duration. Most of the failures that I am aware of have been experienced with the Ignitor II units and not the early Ignitor I. They also provided both cars with a much better throttle response. If maintaining a breaker points based ignition system were so trivial, manufacturers wouldn't have gone electronic a couple of decades ago. Have you ever used Pertronix Ignitor yourself? What are your comments about horrible reliability based on?
Old May 20, 2009 | 07:51 PM
...Roger...'s Avatar
...Roger...
I've had good luck with the pertronix units. My feeling is if the distributor is in good condition you wont see any difference between the pertronix and points. But if the distributor has some wear and allows the dwell to vary the pertronix unit will forgive this and the engine will run better. I've experimented a little by taking a car that that has worn dist bushings and allows the dwell to vary and was breaking up around 4000 and installed the pertronix and the car would then run on up to higher rpm. Rebuilt the dist at a later date and reinstalled the points. This could be one reason some feel a difference in performance.
I "was" able to make a 54 start better by installing a pertronix and using an extra capacitor so the battery voltage to the dist didnt fall to a critical level.
Old May 20, 2009 | 11:29 PM
7T1vette's Avatar
7T1vette
My 2 cents.... With points, you can tell when the ignition system is "going south" way before it will leave you stranded; with electronic ignition systems, when they go, the car's dead.
Old May 21, 2009 | 12:38 AM
Skip Burney
I keep a set of old points and condenser in the glove box just in case, if the pertronix dies it is really easy to change back to the points, the boxes are about to crumble they have been in there so long.
Old May 21, 2009 | 10:01 AM
gkz's Avatar
gkz
Installed one on my '65 F100; no problems; 2MPG improvement
Old May 22, 2009 | 03:14 PM
kapla74's Avatar
kapla74
I put the ignitor 2 1 year ago... only thing I set the gap wrongly and the pick up ring rubbed the module...appart from that car runs fine. I corrected the gap last week when replacing the dizzy main shaft...now it runs better...hahah stupid amateur mechanic me....
Old May 22, 2009 | 03:39 PM
blueray72's Avatar
blueray72
Opinions:
Would you rather replace a 30 year old dizzy or just rebuild it?
sorry for the hijack.
Old May 22, 2009 | 03:55 PM
kapla74's Avatar
kapla74
yeap
I though so once but I was looking to keep the tach drive... and new dissy with tach were in the 300 and up but then I saw ones in around 150 but that was after I went petronix.. and as I had that well just decided to rebuilt.. anyway the rebuilt ended up ok...car runs strong up to 140mph with no problem....is that ok???
Old May 22, 2009 | 06:15 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
I run the Ignitor kit in five cars. No problems, ever.
I disagree that there wouldn't be a performance difference between stock points set-up and the Ignitor kit.
First, I can run a full 12v to the Ignitor FlameThrower coil and that has to mean a better spark to the plugs. Stock coils and points ran on 6-9v to prevent the points from frying.
Secondly, single points set-ups weren't much good much past 5500 RPM. With the Ignitor kit, I often rev my two SB cars to 6500+ without ever missing a beat.
And the best part is, everything looks completely stock.
FWIW
Old May 22, 2009 | 07:07 PM
Solid LT1's Avatar
Solid LT1
OK, I've been using them since 1980 when they were introduced by the Per-Lux lighting corporation and only had 1 issue due to my fault of not properly checking clearances after installing a unit ( I caused a high RPM miss due to rivets losening when the magnet wheel rubbed the pick-up unit when I did'nt properly set clearances.). I run them on most of my old Chevy's and Ford's with no roadside strandings EVER! I guess they don't like the cold enviroments of the Great White North or you and your buddies the McKenzy brothers did the install while downing too many Molsens (EH? Hoser?)
To purtronix electronic ignition
Old May 23, 2009 | 10:44 AM
KB9GKC's Avatar
KB9GKC
Hello,
Car will start better, idle better and run better at high RPM.
Points worked when that was all that was available but the electronic pickup precisely controls the spark duration and collapse at all RPMs.
Installed on 68 Camaro, 65 Mustang and 72 Corvette with 454, all run better in every way.
Douglas in Green Bay
Old May 25, 2009 | 08:00 AM
Mike Ward's Avatar
Mike Ward
Not only do you seem to hate the NCRS, you seem to be biggoted against Canadians. Get a life loser.
Old May 25, 2009 | 10:01 AM
imariver's Avatar
imariver
I put a pertronix set-up in a 65 Buick 401 nailhead, ran it for close to 15 years with no problems. It did run a lot better at Idle and I did notice a slight improvment in gas milage. As far as performance?..... well we all have different definations of what performance is.
if the engine runs better and there is an increase in mpg, then I would have to say that, yes, there was an improvment in preformance.
BTW, that 401 had over 150K on it and never been apart and could suck the doors off anything going up the Grapevine ! WOO- WAHH
