Making progress '69 frame off
Old May 20, 2009 | 10:10 AM
ED69ray's Avatar
ED69ray
Default Making progress '69 frame off
Just installed the fresh 3:70 rear end with all new hardware and spicer solid u-joints. Rebuilt trailing arms with new E brake hardware as well. Rear end is just about done. Still need to install front steering gear and plumb the PS.
Motor is patiently waiting The body shopuld be meeting the frame in the next couple weeks.
Next time I will buy a car already completed
Ed
Old May 20, 2009 | 11:33 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Looks great Brings back fond memories of the frame off I did on my 65. One frame off a lifetime. It's alot of work. When I bought my 68 it was done. You do get a great sense of satisfaction when it's finished. A little paranoid when you first start driving it though.
Old May 20, 2009 | 11:37 AM
C3 4ME's Avatar
C3 4ME
Looks great. Can't wait to see more pictures. I often wonder if I'll ever have the cajones to do a frame off.
Old May 20, 2009 | 11:45 AM
markdtn's Avatar
markdtn
Nice
Old May 20, 2009 | 11:53 AM
72LS1Vette's Avatar
72LS1Vette
Looks great. I was at that point last summer and now I'm working on the remaining 1,000 small projects left to finish the big project. It's so nice to be able to get at everything easily without the body on.
Did you use the VB&P SmartStrut bracket on the rear suspension or the original?
Rick B.
Old May 20, 2009 | 06:00 PM
Alan 71's Avatar
Alan 71
GREAT PICTURES!!!!
I love seeing a chassis and running gear being built! I think it's the most beautiful part of the car.
MORE PICTURES NEEDED!!!!
Regards,
Alan
Old May 20, 2009 | 08:23 PM
TWINRAY's Avatar
TWINRAY
Just setting a hook into this thread.
Old May 20, 2009 | 09:47 PM
ED69ray's Avatar
ED69ray
definitely words of wisdom
I am fortunate in that I am not touching the body - a local shop is taking care of that.
Satisfaction will come with that first blast thru the gearbox
Old May 20, 2009 | 09:53 PM
RobRace10's Avatar
RobRace10
Ed
What, and miss all the fun? I'm with you, it will be a long time if ever for my next frame off once my current one is completed.
Keep up the good work, looks great.
Old May 20, 2009 | 10:02 PM
ED69ray's Avatar
ED69ray
Rick B.
I am using the SmartStrut bracket - I have the complete Perf Plus kit incl the dual mount front monospring.
You are right about easy access without the body - only problem is the tempation to rebuild everything while its easily accessable
What started as a simple brakes and suspension overhaul has turned into a full restoration.
Old May 20, 2009 | 10:23 PM
72LS1Vette's Avatar
72LS1Vette
I saw the cam bolts on your bracket and I couldn't tell from the pics if you were re-using the stock bracket or not. One of those jobs I ended up doing twice because the package didn't include instructions as to which hardware to use, and I didn't fully understand the mechanics of the SmartStrut.
I understand completely about the temptation to rebuild everything 'while I'm at it.' My project started out as an engine swap - banged on the frame and found a few holes- found a few more holes - 2 years later the body is back on a replacement frame. Of course the brake lines and all bushings needed to be replaced 'while I'm at it'.
It is nice to be able to crawl under the car and look up at either new or clean, painted parts though.
Rick B.
Old May 21, 2009 | 12:14 AM
vettebuyer6369's Avatar
vettebuyer6369
Nice job on the body-off.
Keep the pics coming.
Old May 21, 2009 | 08:06 AM
schmegeggie's Avatar
schmegeggie
Looks like progress! Keep the pics coming.
Old May 21, 2009 | 09:58 AM
Hadez's Avatar
Hadez
I think you might want to reverse your "SmartStrut bracket" so that the cam bolt head are on the rear. This way you can more easily spot check them from the rear of the car if they have moved after an alignment (if you chalk mark them). Otherwise you are going to have to look from under the car just infront of the rear wheels backwards at the differential.
Looks like a fun & rewarding project.
Old May 21, 2009 | 10:33 AM
ED69ray's Avatar
ED69ray
Rick B.
Similar situation here - frame rust was much worse than anticipated - once the body was pulled the full carnage was revealed
This is a replacement chassis - I bought it with the PerfPlus kit already installed. It looks like they used the stock cams along with the VBP bracket. Talked to VBP tech line and they confirmed the stock cams work fine with their setup.
Rear end was a 3:08 so it had to come out - I had my original 3:70 rebuilt. I then decided to disassemble everything to ensure it was properly assembled and torqued to specs. I had the trailing arms rebuilt as well.
I am taking it slow and steady - too deep into it at this point to rush and cut corners.
I'll post more photos when I get the front end done,
Ed
Old May 21, 2009 | 10:37 AM
ED69ray's Avatar
ED69ray
thats a good pt - the bracket only mounts one way as the mounting bolts are offset but the cam hardware can be reversed
Old May 21, 2009 | 11:45 AM
70BBvert's Avatar
70BBvert
Lookin' good Ed Keep up the good work
Jim
To Making progress '69 frame off
