Fuel Pump Replacement.....
Old May 26, 2009 | 03:16 PM
justin_heat05's Avatar
justin_heat05
Default Fuel Pump Replacement.....
I have a 79' L48 and I'm getting ready to replace the fuel pump. It works but when it sets overnight, all the gas leaks back down and I have to pump the gas about 20 times to get it built back up.
Anyone have some helpful advice, procedures or a heads-up before I take off the old one? I've never replaced one before.
Old May 26, 2009 | 03:29 PM
spedaleden's Avatar
spedaleden
If your going to replace it. Remove the two mounting bolts through the passengers side wheel well.
When I had a boat it did the same thing. I would crank it for 15 seconds to build pressure then pump the throttle two times and it would start right up.
...Roger...'s Avatar
...Roger...
Here is a thread where we talk about holding the fuel pump rod up with a tool through the front of the block and also how to get to the bolts that hold the pump from under the fender. The tool can be made by grinding the threads off a bolt.
edit--oooops forgot the link-- http://forums.corvetteforum.com/c3-t...placement.html
Old May 26, 2009 | 03:48 PM
kapla74's Avatar
kapla74
wheres that thread dude!!! jaja
Old May 26, 2009 | 04:34 PM
BKbroiler's Avatar
BKbroiler
Before you change the pump - are you sure that its bad? The description you gave could be a carburetor problem. A bad fuel pump would usually cause the engine to die while you are accelerating.
Old May 26, 2009 | 04:52 PM
rcread's Avatar
rcread
The problem is that today's fuel evaporates faster in your carburetor than fuel from ten years ago. The only way to fix it is to go with an electric fuel pump.
Old May 26, 2009 | 04:53 PM
smon's Avatar
smon
Also try a fuel filter that keep fuel from backflowing. Only a couple bucks and it should help
Sean
Old May 26, 2009 | 05:37 PM
...Roger...
Ooops forgot the thread from earlier post.
Old May 26, 2009 | 10:10 PM
7T1vette's Avatar
7T1vette
Remove right/front wheel. Use 2 squeeze-type clamps (or vise grips, small C-clamps, whatever...) to stop fuel flow in the flexible lines at the pump. Remove fuel lines then the pump. Before you install the new one, turn engine over enough to put drive pin in "UP" position [so there is no resistance on the pump arm]. Put grease on the drive rod to keep it in UP position, then install the pump.
Old May 27, 2009 | 11:27 AM
Ganey's Avatar
Ganey
The Q-J has casting plugs that can leak- if it sits long enough it leaks down- common.
Old May 27, 2009 | 09:29 PM
...Roger...
Just curious,how are you getting the grease on the rod are you talking about putting grease on the outside of the rod or are you removing the rod and putting the grease on the cam end of the rod ?
Old May 27, 2009 | 10:41 PM
zmanc3's Avatar
zmanc3
Hate to tell you, but changing the fuel pump is not going to solve this. My origional engine did this and my crate motor does the same thing with new fuel pump, in line fuel filter,and THREE different carburetors.
I agree with the response that the fuel is evaporating faster now than in the past.
I have an EDL-1400 on it now. I moved the accelerator pump connection to the quickest response, push the pedal to the floor three times, cranks about 5 seconds and starts.
I you don't want to do this "technique", I also agree an electric fuel pump is what will be needed. A check valve in the fuel line might be something to consider also.
And it would'nt hurt to verify you have the engine tuned, incliuding the carb. Anything out of wack, will increase "cranking time"
zmanc3
Old May 27, 2009 | 11:40 PM
...Roger...
If you suspect the problem is that the fuel is returning to the tank its easy to prove-just clamp the rubber hose between the fuel pump inlet and the steel line going back to the tank. Leave the car sit a couple days and try to start-if it starts it was draining back.
Old May 28, 2009 | 07:20 AM
Ganey's Avatar
Ganey
outside of the rod
Just put a little on the rod & push back up.
Old May 28, 2009 | 02:45 PM
justin_heat05
I could live with the pumping. Thats not the only reason I'm replacing it though. I want to make my car a little more dependable so I can drive it to car shows and other sorts. Hate to be stuck on the side of a road because of a failing fuel pump and have to call a wrecker to tear up my car. I think it still has the original fuel pump. Are airtex fuel pumps any good?
Thanks for the advice guys.
To Fuel Pump Replacement.....
