panel door panel mounting points stripped
Old May 26, 2009 | 03:56 PM
greg75vette's Avatar
greg75vette
Default panel door panel mounting points stripped
Not too long ago I replaced my window regulator on the passenger side of my car. Long story shot, I had to take the inner door panel off quite a few times. Well, apparently this stripped out the holes for pull handle and some of the other mounting hardware. Must have been weak to begin with.
My question is how do I go about repairing this? My thought was to tap the holes for a larger bolt. However, would it be better to just get a courser thread of the same diameter? Or should I do both? I know in the door pull handle, they are machine screws with a fine thread, which I assume is like that for a reason.
I just want to make sure I make the best repair possible. I realize this is a bit of a trivial question, but I never had an issue with a sheet metal threaded hole before What do you guys think?
Old May 26, 2009 | 05:21 PM
CCrane65's Avatar
CCrane65
Greg, you could try a hammer and a body dolly to "shrink" the holes back up. Too much though and you will have to re-tap them.
cc
Old May 26, 2009 | 05:37 PM
bluthundr's Avatar
bluthundr
Same thing happened to me. I ended up getting some license plate anchors from the local HELP! section, drilled the holes out a bit bigger to fit, and popped them in.
Old May 26, 2009 | 09:37 PM
Bronze76's Avatar
Bronze76
If you can, get yourself one of these kits...
http://www.daggertools.com/m5_view_i...m5:item=DT1440
I find them very handy. They are like little rivets that have threads inside to receive common bolts. They are pretty strong too. The most common size I use is 1/4-20 but you should be able to use the smaller sizes for your door handle.
Old May 26, 2009 | 09:44 PM
7T1vette's Avatar
7T1vette
The door panel attachment screws shouldn't really have that much torque applied to them. The door pull handle screws will take more, as they are larger screws. My suggestion is to fill the holes 9and some extra behind the holes) with JBWeld 'putty stick' epoxy and then drill some new holes for the correctly sized screws. Then, don't put as much torque on them. {If you can get at least 3/16" thick of epoxy at each hole, it will hold up just fine.}
Old May 27, 2009 | 07:41 AM
BTAL's Avatar
BTAL
St. Jude Donor '09
I used the putty stick product then redrilled. Worked just fine.
Old May 27, 2009 | 10:59 AM
pbcanney's Avatar
pbcanney
my plans for my stripped holes is to mig weld them up, grind the slag down and redrill the hole.
Old May 27, 2009 | 11:14 AM
greg75vette
Thanks for the replies!
cc
I don't know if I can get a dolly up there especially for the door handle bolts (my biggest concern) because my regulator comes very close to hitting the screw (already did hit, that started part of the problem).
I kinda liked this idea. Hoe much can they hold (in force)? I think this would work well for the door panels but not to well with my door handle.
This is pretty cool. Where do you get refills though?
I have some JB weld. It's the two part/ two tube kind you mix and spread. Is that different than the putty stick? I've never seen that.
As far as over torquing them, I don't believe I did. They were pretty weak when I first took it off. I think the damage was done before I even got there. The only one I 'helped' along was the door handle screw. The screw caused interference with my new regulator (same screw didn't hit my regulator) and one of the arms bent the screw. When trying to back it out, the threads were trashed. I didn't have too much of a choice though.
I think I'll try out the JB weld out first and see where that goes. I don't think I would be making it any worse by trying that out. I guess I need to find this putty stick.
Thanks again!
Old May 27, 2009 | 02:42 PM
7T1vette's Avatar
7T1vette
The 2-part 'glue-type' epoxy is not what you want to use. It is too brittle for repeated screw applications. The 'putty-stick' type comes in a clear plastic tube and looks like a stick of clay. It has both parts in a stick form and you just cut off a chunk and knead it until it mixes. Sets up in less than 5 minutes; cures hard in an hour. Cut off only what you need at the moment so you don't waste a bunch. It would be better if you could put the 'glob' on the back-side of the hole and squeeze some through the hole to spread out on the front side. That will give you a larger amount on back that will support more screw stress. Any auto parts supply or hardware store will sell the stick epoxy.
Old May 28, 2009 | 08:57 AM
greg75vette
Ok then. Sounds just like "Mighty Putty." Or maybe it's the other way around...
I'll get some and give it a shot this weekend. Thanks again!
Old May 28, 2009 | 12:05 PM
jaki30's Avatar
jaki30
Default try this
Get yourself a Vice Grips type plier. The deep head that will reach to the holes. Then, clamp the pliers closed over the open holes. This will force the metal back to the center of the hole. Almost the same as the hammer and backup pounding to fill the hole back in. Since there isn't much force on the screws or the panel, this will work.
Old May 28, 2009 | 03:54 PM
Saint's Shark's Avatar
Saint's Shark
You might also consider using PEM inserts (by Penn Engineering). It's on the same idea as using the license plate anchors - you drill a larger hole and press fit them in. They're specifically designed for applications like this and can take a good amount of torque since they're knurled/press fit - and they're metal. In fact, I think some of them are hardened, depending on your application. I know that McMaster-Carr sells them as well as other industrial and machine shop suppliers (i.e. Graingers).
Here's a link;
http://www.pemnet.com/fastening_prod...for+Sheetmetal
You might just be able to request some samples instead of buying any quantities!
Old May 29, 2009 | 07:57 AM
greg75vette
This is an elegant idea. I like it, but I don't have any vice grips of that style or that can reach that far. It may be time for an investment.
Here's a link;
I never even knew these existed. I'm just not sure how to install them. In the .pdf they mention a punch and anvil being used, but I don't know enough about machining to pick out the right one. I'll search on the site and see if I can find what's needed.
Old May 29, 2009 | 11:49 AM
Saint's Shark
You can call them direct and talk to them about your application. Some of them do require that technique, but not all of them. I've used some that are press-fit in from the front.
Old Jun 1, 2009 | 08:40 AM
greg75vette
Well, I gave the JB stick weld a shot on Saturday and seems to be holding. I definitely did not have full access behind most of these holes, but pushing the weld thru the hole and keeping a flat blade screw driver behind still seemed to work.
The ultimate test was yesterday when my girlfriend and I took the vette out to the Hamptons for a cruise. She must have shut the door 20 times yesterday and it all held
Thanks for all the advice. If this JB stick weld doesn't hold I have enough other options to keep me busy for a while.
To panel door panel mounting points stripped
