Header question
Old May 28, 2009 | 09:34 AM
Dr L-88's Avatar
Dr L-88
2025 Corvette of the Year Winner- Modified
2024 C2 of the Year Winner - Modified
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
Default Header question
What are the best header gaskets for aluminum heads and which header bolts are best? Any locktite required on header bolts?
Thanks,
Rex
Old May 28, 2009 | 04:37 PM
Duke94's Avatar
Duke94
I'm surprised you didn't get a hundred different opinions on your question. I used the Stage 8 locking fasteners and Percy's multi layer soft copper gasets on my Edelbrock Aluminum heads. Been on for about 5 years and never had a bolt come loose or a gasket leak.
Gary
Old May 28, 2009 | 05:07 PM
vettesbydesign's Avatar
vettesbydesign
Rex...I got your pm.The above are good,and the Cometic,and SCE Pro copper.
I can't speak for clearance problems,but I put studs in the exhaust,and locktited them,but this is SB Brodix appl.
When you decide what you are after....give me a shout.I carry Cometic,Fel-Pro,Flatout Graphite,Mr.Gasket,Mr.Gasket Ultra seal,Mr.Gasket Copper seal,Mr.Gasket aluminum seal,and the SCE Pros for the BBs.
Old May 29, 2009 | 05:26 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Gary
Have them both in my garage in case I get the urge (energy) to switch to hooker side mounts. Over the years on this forum the two above mentioned items always seemed to surface & work.
To Header question
