vacuum headlight problems
Old Jun 4, 2009 | 02:27 AM
cosmicvette's Avatar
cosmicvette
Default vacuum headlight problems
Hi everyone,
ok have just installed a new dewitts radiator and also hooker headers and side exhaust. The car is running (haven't done the timing as I need to get a timing light). anyway, I was eager to take the car around the block last night...the headlights wouldn't pop up. They did work before (sort of), one headlight popped up, and one needed a little assistance. Anyway, now neither of them would go up, so I manually pushed them up.
They will not come back down! the manual override is off.
I don't know why I suddenly have this vaccum problem. I haven't disconnected anything.
I did a search and found a post that said:
"Your headlight parts may need some oil but they should not be stuck closed, you can reach under your Vette and move them up and down a little. Don't push them up to far or they will stay up! Just move them a little to prove that they do move."
So, relating to the comment posted above, have I done something bad by pushing them up by hand? Why would they 'stay up'? and not come back down.
Old Jun 4, 2009 | 02:34 AM
toolman1981's Avatar
toolman1981
Sounds like something my Mom said to me a long time ago "If you keep looking at your sister cross-eyed someday they are going to stay that way" LOL
Old Jun 4, 2009 | 07:25 AM
imariver's Avatar
imariver
Even if you push them all the way up, you can still pull them down, BUT ONLY if you reach under and pull on the mechanism that opens them. Never try to push them down by pushing on the headlights themselves. There are springs on the mechanism that keep the lights up by default. Look at the mechanism, study it, understand how it works. This system is not rocket science and IMO is easy to trouble-shoot. A propertly maintained system will still work even with low vaccum
Old Jun 4, 2009 | 08:01 AM
69MA's Avatar
69MA
You will not hurt your headlights by opening and closing them by reaching under the car and tugging on the mechnisum in the correct place. As imariver suggest take a look and you will see how it works. BUt you have a vaccum problem. You had one before you installed the radiator and by replaceing it you probably moved some vaccum line around and either knocked one off or they are so old that they need replacing. The best thing that i did when i first got my car with headlight issues was purchase a vaccum hose kit. This way you have a baseline and you know your hoses are good after that i had to replace one relay and it has been fine ever since.
Old Jun 4, 2009 | 08:48 AM
...Roger...'s Avatar
...Roger...
Does the wiper door still go up and down ?
Old Jun 4, 2009 | 10:06 AM
FF 1045's Avatar
FF 1045
Un plug your hoses at the headlight and with a short
length of tubing connected to the rear of canister ( down side) see if you can suck the light down.
Then try the front side (up) . If the linkage can be moved by hand and not rusty you need a seal kit.
All the corvette suppliers have them for about $30.00 .
(for both sides)
Just make sure you get the "retainer ring" too.
Some kits have just the seals.
Old Jun 4, 2009 | 10:37 AM
justanotherdoe's Avatar
justanotherdoe
Originally Posted by cosmicvette
Hi everyone,
If you installed a radiator and headers without dicsonnecting any vacuum lines, you may have cut one, pinched one, or knocked one loose.
Check that you have vacuum at the relay for both the control signal and the main lines. If not, work backwards to the connection you use for the vacuum source.
Old Jun 4, 2009 | 06:27 PM
Alan 71's Avatar
Alan 71
Hi CV,
There's an 'knee' shaped part of the linkage that needs to be pulled down to release the headlight mechanism. It locks the headlight in the up position. The vacuum actuator has enough power to overcome the 'lock', but YOU need to pull it to get the headlight to go down by pushing it by hand.
Perhaps you might want to think about getting the GM CHASSIS SERVICE MANUAL for your car, it'll help you with little jobs like this. Wilcox has a lot of vacuum trouble shooting help on this site too, if you search.
Regards,
Alan
Old Jun 4, 2009 | 11:04 PM
Trucks_69's Avatar
Trucks_69
it's a real bitch when those vaccum lights don't work... that's why i went electric... much easier
To vacuum headlight problems
