Engine Compartment Paint...
Old Jun 8, 2009 | 04:17 PM
FRSTR90's Avatar
FRSTR90
Default Engine Compartment Paint...
What have you guys used for painting your engine compartment? I would like to use something that is not an aerosol. My 2 reasons for not wanting an aerosol is 1) I don't want overspray on everything and 2) Aerosol paint seems to be more brittle... So what are your suggestions ands thoughts??
Old Jun 8, 2009 | 06:29 PM
Alan 71's Avatar
Alan 71
My thought is that to do a good job you need to use spray paint. I fully understand the work involved in doing this.
Regards,
Alan
Old Jun 8, 2009 | 08:13 PM
FRSTR90's Avatar
FRSTR90
That looks really nice!! I guess I can kind of see where you are coming from. I was thinking about painting it on with a foam brush, color sanding, and buffing by hand. What type of paint did you use?
Old Jun 8, 2009 | 08:20 PM
OURSHARK's Avatar
OURSHARK
Alan is correct, spray paint will give you the best results. Your way of doing it is much harder, just cover and tape off what you don't want to paint. I used Duplicolor satin black.
Old Jun 8, 2009 | 09:35 PM
FRSTR90's Avatar
FRSTR90
I'll take your guys advice... I currently have my engine out anyway... So i guess it can't be that bad! My goal is to make engine compartment look pretty and not like a nightmare like it did before. I don't think it is really going to matter what I do when people see a brand new big block sitting under the hood!
Thanks for the advice!
Old Jun 9, 2009 | 12:33 AM
SEVNT6's Avatar
SEVNT6
Here's what I was able to do with spray. We all know what a nice job the factory did to finish the firewall so I thought I'd do something about it. I filled & smoothed until it looked like one piece, the way it should of been. I used Dupli-Color primer & engine enamel, 3 coats of each. Satin is correct but I went gloss to add a little bling......
Old Jun 9, 2009 | 07:55 AM
schmegeggie's Avatar
schmegeggie
Just finished painting my firewall and engine bay over the weekend. Motor is out, but there are lots of wires and hoses in place. I saved paper towel and TP rolls for about 3 months and used them to covers everything. I don't have any pictures yet, but it looks great. Can't wait to get the motor in!
Used a low gloss black epoxy paint, shot on with air brush. Moved things out of the way all the way around. I'll post some pics later on down the road.
Old Jun 9, 2009 | 08:21 AM
Virginia Vettes's Avatar
0Virginia Vettes
Former Vendor
Virginia Vettes has the John Deere Matt Black in quarts and spray cans.
The quart kit includes a quart of paint, a pint of reducer and a half pint of catalyst ......Price $40
The 11oz. spray can is .........$6
We aslo have Semi-Gloss Black Lacquer in spray cans at ........$6/can.
Most customers use the former for engine compartments
Virginia Vettes
1-757-229-0011
Old Jun 9, 2009 | 07:19 PM
Alan 71's Avatar
Alan 71
Hi F90,
I used Krylon #1613, semi-flat black. It's getting VERY hard to find, my next choice is the spray that VV mentioned, the John Deere Blitz Black.
Regards,
Alan
Old Jun 9, 2009 | 08:48 PM
C3 4ME's Avatar
C3 4ME
I too have always used Krylon 1613. The last I looked I THINK you can still find it on the internet, in case quantity.
Old Jun 10, 2009 | 06:55 PM
Alan 71's Avatar
Alan 71
Hi C3,
Thanks for the heads-up!!!!
Regards,
Alan
Old Jun 10, 2009 | 07:31 PM
MakoShark72's Avatar
MakoShark72
Krylon Fusion is made to paint fiberglass and plastics, Satin Black.
Old Jun 10, 2009 | 09:04 PM
busterpelvis's Avatar
busterpelvis
Just bought some Krylon semi-flat at MEIJER
Old Jun 10, 2009 | 10:32 PM
74 LS4-454's Avatar
74 LS4-454
Finalist 2020 C4 of the Year - Unmodified
Default found it today.....
on vaca up in Maine, stopped at Wal Mart for a few items and what do I see, but Krylon # 1613 Satin Black @ $2.94 per can, bought a case of 6, couldn't pass up the price...
also what is your opinion for Krylon Pumpkin Orange to use for the engine, is it the correct orange (the cap looks good and so does the pic) , and will it withstand engine heat??? thanks....Tom
PS: all of the above engine compartments look great, can I hire you guys????? Hope mine will turn out just as good as all of yours did....nice job
Old Jun 11, 2009 | 01:57 PM
VettePower's Avatar
VettePower
Kylon paint won't hold up to the heat of an engine block...
Old Jun 11, 2009 | 02:07 PM
rayluka's Avatar
rayluka
To bad your not close. Id do it
Old Jun 11, 2009 | 03:03 PM
fdunford's Avatar
fdunford
Alan 71, SEVNT6, rayluka,
Your engines look great. If NCRS, please tell if you had it NCRS judged after painting and if so, what did you repaint, and did you take a points ding for repainting?
To Engine Compartment Paint...
Old Jun 11, 2009 | 03:19 PM
FRSTR90's Avatar
FRSTR90
How about the heat of the engine compartment... If I go with krylon.. my paint isn't going to soon start peeling or flaking off will it?
Old Jun 11, 2009 | 04:19 PM
C3 4ME's Avatar
C3 4ME
Krylon is fine for the enigine compartment, not the engine itself. I painted mine with 1613 2 years ago and its still holding up fine. I can personally attest to people who have had it last many many more years than that.
Old Jun 11, 2009 | 04:21 PM
fe1ixdakatt's Avatar
fe1ixdakatt
Thanks for the pics, fellas! Gave me some great ideas. I'm in the same boat... my firewall looks like crud and needs to be cleaned up and repainted, but I just dropped the new engine in back in October and I don't want to go through the hassle of taking it all back out.
