Engine Compartment Before & After
Old Jun 15, 2009 | 11:17 PM
EIGHTY's Avatar
EIGHTY
Originally Posted by another-user
i hope mine comes out half as well when im done.
heres what i started with
and heres what im upto
i should be ready for paint this weekend, if my timing chain and gears get here in the next day or two.
You've come a long way!!! Luckily my engine only had a few coats of dirt/oil/grime. I guess you just have to keep scrubbing, and it will eventually come off. I kept going til my hands were about to fall off!
Old Jun 15, 2009 | 11:21 PM
EIGHTY's Avatar
EIGHTY
Originally Posted by earthquake68
The master cylinder should be raw cast iron. They have spray paint called, "cast blast", it looks exactly like new, raw cast iron when you're done. My all stock '82 has a black brake booster. Well, .....it used to be, anyway.
Great job, by the way! I'll have to let you know when I'm ready to do mine.
Cast gray is the color I'm leaning toward for the master cylinder, but I'm worried about the brake fluid eating up the paint. Do you know of any paint that won't be harmed by the fluid? Also, why do people paint the brake booster gold? I've seen that a few times...
Old Jun 15, 2009 | 11:29 PM
earthquake68's Avatar
earthquake68
The booster came on a few models in an electra coat. It kinda looked like gold annodizing. If you look at the Eastwood catalog, you can buy a kit to reproduce this finish. No paint that I'm aware of will stand up to brake fluid. It'll be fine for a while, especially if you don't pull the lid off too often to check the brake fluid. (hint: no fluid on the ground = full master cylinder)
Old Jun 15, 2009 | 11:36 PM
Goody's Avatar
Goody
It isn't painted gold, actually it is the Zinc coating that is applied to some of them....Like mine.
Old Jun 15, 2009 | 11:42 PM
myoriginal77's Avatar
myoriginal77
Wow - Great Job !
Frank
Old Jun 16, 2009 | 12:16 AM
EIGHTY's Avatar
EIGHTY
Thanks for clearing that up for me. I'm going to paint the master cylinder with cast blast and the brake booster with semi-black. If I have left over cast blast I might tackle the exhaust manifolds, but they are covered up by those shields so they aren't too visible to worry about...we'll see.
Thanks everyone!!!
Do you have any pictures of your brake booster? Did you do it yourself?
EIGHTY's Avatar
EIGHTY
Originally Posted by myoriginal77
Wow - Great Job !
Frank
Thanks Frank!
Old Jun 16, 2009 | 03:40 AM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
The power booster is originally gold cadmium plated on the later C3s. Not quite the same finish as the master cylinder cap which is gold iridite.
Old Jun 16, 2009 | 10:28 AM
7T1vette's Avatar
7T1vette
Use the Seymour cast blast (ceramic paint) for the exhaust manifolds, as it is rated for 1500 F; I used it and it works great....bakes on from normal manifold heating. Since you won't be able to heat up the M/C, I don't recommend the Seymour paint for that; use VHT or other engine heat rated 'cast iron' color paint for the M/C. You're doing a fine job...
Old Jun 16, 2009 | 10:45 AM
killain's Avatar
killain
Oldtimer
Thanks!!! Yea I was scrubbing for a few hours til it got dark. Then I painted the valve covers which was not fun...taking them out sucked, but seeing them look better is well worth the sweating and back pains If I ever loose my oil cap I'll send you a pm too.
OK, if you ever need them just let me know. Their free.
Old Jun 17, 2009 | 03:08 AM
jimo's Avatar
jimo
After many hours of much needed scrubbing with a toothbrush, a gallon of purple power and some paint:
mate!! worth the effort, looks good
Old Jun 17, 2009 | 09:07 PM
EIGHTY's Avatar
EIGHTY
thanks
Old Jun 17, 2009 | 09:18 PM
  #33
Flying Low's Avatar
Flying Low
Great job! That "elbow grease" stuff really works well.
Old Jun 17, 2009 | 11:47 PM
  #34
EIGHTY's Avatar
EIGHTY
yea the elbow grease was on sale at walmart so I bought some...it was well worth the price
thanks
