Electric Headlights Cheap!
Old Apr 20, 2012 | 09:15 PM
U17's Avatar
U17
I hang around a friends shop that mostly builds tools for buiding sheet metal planes,RV series, BUT a side job he has had for years is building the actuators for Firebirds headlights... He uses motors from Graingers and makes the rest...
Old Apr 21, 2012 | 12:50 AM
myoriginal77's Avatar
myoriginal77
Old Apr 21, 2012 | 10:09 AM
Jeffery73's Avatar
Jeffery73
St. Jude Donor '08-'09-'10-'11-'12-'13
Don't mean to be a downer but those Firebird motors are poor quality. My Dad has a '95 T/A and has gone through a bunch of them.
Old Apr 21, 2012 | 12:43 PM
7T1vette's Avatar
7T1vette
You guys know that you tagged onto a 3 year-old thread, don't you?
Old Apr 21, 2012 | 01:21 PM
zigvs's Avatar
zigvs
yes I did and now its a new thread.I did a search as not to annoy others and here we gooooo
Old Apr 21, 2012 | 02:49 PM
7T1vette's Avatar
7T1vette
It's no problem....but thought you might not expect the OP to respond.
Just giving you a 'head's up'....
Old Apr 21, 2012 | 03:09 PM
Zorro O's Avatar
Zorro O
So it's been three years (more like 44) what does anybody have to show in the way of electric headlight doors, for a C3 Corvette? Got pics?
Zorro
Old Apr 21, 2012 | 04:34 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Did your dad try the $35 bronze gear replacements? Throwing money at the stock nylon gears is silly. There is nothing at all wrong with the motors themselves.
Zorro
There are plenty of threads and articles out there about the now-unavailable McSpeed kit. I've got almost everything I need to do it myself, with the exception of the left-hand Firebird motor.
Old Apr 21, 2012 | 05:02 PM
AdamMeh's Avatar
AdamMeh
Originally Posted by lowbuck72
Been wanting to can the vacuum headlights for electric for a while now. Being the cheap b*stard that I am, I didn't want to pay big bucks for one og those kits. I know the vacuum actuators have about 4" of travel, and saw 4" linear actuator on ebay for about $150 a pair. Then I ran across a pair of Linak 4" linear actuators for $60 a pair, $75 with shipping, except that they were 24 volt instead of 12 volt. I figured what the heck. I tested them with a 12 volt battery and they moved about an inch every 3 seconds, or about 12 seconds for 4" of travel. I removed my buckets and replaced the vacuum actuators with the new electric ones. I made 2 "L" bracket housings out of steel for each one, and I replaced the original pins with 3/8" bolts. I had to modify the aluminum housing for clearance, bought a double pole, single throw toggle switch, which I mounted under the dash in the headlight overide position. The acuators sit in front of the radiator with no clearance issues, except, I had to modify the hood prop rod, shortening it about an inch, so now the hood does not open quite as far, but is still plenty accessible. They work like a charm, but take about 12 seconds to fully open or close, not bad for under $100. I should be able to sell by vacuum switches and actuators for much more than that on ebay. Then maybe, I'll buy some 12 volt actuators, which should make them open and close twice as fast. I'm sorry I did not take any pictures while the hood was still off, because they're very difficult to see with the hood on.
Could you post up a link to the motors you found? I'd be very interested in this.
Thanks!
Adam
Old Feb 27, 2013 | 02:03 PM
holley505's Avatar
holley505
Can somebody post a link to the article please for eletric headlights... we will make a kit of the hold mc speed.
Old Feb 27, 2013 | 02:44 PM
holley505's Avatar
holley505
http://www.vetteweb.com/tech/0408vet...t/viewall.html
Going to see if we can make a kit... who would be interested?
Old Feb 27, 2013 | 04:19 PM
kanvasman's Avatar
kanvasman
Follow this thread towards the end where he uses ford probe motors. That seems to be the easiest way to make them work & simplest to wire.
http://forums.corvetteforum.com/c3-t...c-new-way.html
Old Feb 27, 2013 | 08:30 PM
  #33
dgood's Avatar
dgood
I would be interested in a kit as long as it didn't cost an arm and a leg.
Old Feb 27, 2013 | 08:39 PM
  #34
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Much easier than using the Firebird motors that require a seperate controller.
Old Feb 28, 2013 | 12:34 PM
  #35
holley505's Avatar
holley505
Ageed...looking into this
Old Feb 28, 2013 | 04:27 PM
  #36
929nitro's Avatar
929nitro
Depending on cost I would be interested.
Old Mar 2, 2013 | 08:46 AM
  #37
ctgene's Avatar
ctgene
Banned Scam/Spammer
ditto on the cost factor, I would be interested...
To Electric Headlights Cheap!
Old Mar 2, 2013 | 10:01 PM
  #38
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
I'm in.
Terry
Old Mar 3, 2013 | 08:43 AM
  #39
RickyBerg's Avatar
RickyBerg
Im also interested.
Old Mar 25, 2013 | 03:06 PM
  #40
jesse10886's Avatar
jesse10886
Also interested! My vacuum lines canister filter ect all shot would rather just spend money getting rid of it all
