Looking to get into Vettes
I am 20 and never owned a corvette in my life, but have always admired them. I was driving home from work and saw a corvette for sale.
1972 White w/ Black interior Corvette Stringray with ~72000mi
Modern sound system
He has it up as $9000 (or best offer)
From what I could tell just looking a bit at it (Without looking at the import parts), he seemed to take care of it.
I have not yet talked to him nor driven it or seen the inside.
SOO, getting to the part where I beg for help.
I am interested in this car and I was wondering what I should look for/ ask about.
I apologize if this isn't the right section to do this. But, thank you for any help you can give.
The simplest answer is to find a Corvette Club in your area and ask if someone knowledgeable about 72s would look at the car with you.
Corvettes can be quite deceiving and so can Corvette sellers.
You may have found a great car or you may have found a money pit.
If you fill out your profile someone from this forum may be close by and would be able to take a look at it with you.
Regards,
Alan
Crawl underneath and get a GOOD look at the frame (trust me on this one), especially in front of the rear wheels at the "dogleg". If possible check around the windshield frame. If you can pull the pillar cover back a little you might be able to see. These are the two most notorious areas that can come back to bite you in the butt.
Rust can be easy to hide because most people don't really look for it on a Corvette.
As far as looking for other possible problem areas, just do your research and test everything you can if you get to look at the car. Lights, vacuum system, electrical issues and the list goes on.
The price you listed could be a steal.....and it could be a waste. So just make sure you take someone who is familiar with Corvettes and look at it with your head and not your heart. (Although if your heart is set on it, it will override your logic.....I know mine did.)
Good luck
Dean
They have a way of sneaking up on you and before you know it you have to have one, then you have a strong need to take yours for a drive or at least slide on into the garage to take a quick peek. Working on her brings a pleasure that can't be explained. Driving her is special and the comments and the occasional thumbs up.. well that's just frosting on the cake. You'll only be able to go so long without sitting behind the wheel. If it gets really bad you start thinking about a 2nd one. So be careful.
Mike
