Shift Boot Replacement
Old Aug 6, 2009 | 05:40 PM
pbbergs's Avatar
pbbergs
Default Shift Boot Replacement
I have a 79 manual Vette that I want to replace the leather boot. The fork attachment connected to the stick shift (Reverse pull up) needs to come off.
Does anyone know what is required to remove the reverse pull up?
Thx
Paul
Old Aug 6, 2009 | 06:30 PM
gbvette62's Avatar
gbvette62
Unscrew the shift ball and the "T" handle and rod should lift straight up out of the shifter.
Just be careful, there is a small spring in there that you don't want to lose.
Old Aug 6, 2009 | 09:31 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
If you need more help on this, I have a page for doing the dash pad but it covers the shift console and other parts related to removal starting at the bottom of page 3.
http://willcoxcorvette.com/repairand...lp.php?hID=263
Willcox
Old Aug 6, 2009 | 09:44 PM
pbbergs's Avatar
pbbergs
Default Sounds Easy Enough
Kind of scarey. This sounds too easy.
Thx for all the info
Paul
Old Aug 6, 2009 | 09:48 PM
0Willcox Corvette
Former Vendor
It's not really that hard. . . I've always found it easier to just pull the shift plate out of the car. You don't have to remove it and this may be more work than just going at it from the top side. Some will tell you just do it from the top side and this is possible but it can be hard to get the metal rim of the new boot over the bottom of the console and then align it to the holes.
Willcox
Old Aug 7, 2009 | 11:16 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by pbbergs
...Kind of scarey. This sounds too easy. ...
You haven't gotten started yet.
To Shift Boot Replacement
