head lights
Old Aug 16, 2009 | 09:08 AM
haybail's Avatar
haybail
Cruising
Default head lights
need some help, my head light slam shut on my 1975 corvette, I ordered this car, and I have did nothing to the system, it started doing it this year. Thanks Haybail
Old Aug 16, 2009 | 09:32 AM
Mike Ward's Avatar
Mike Ward
Not a clue what you're trying to ask.............
Old Aug 16, 2009 | 09:40 AM
...Roger...'s Avatar
...Roger...
Small hose fell off headlight relay ???????????
Old Aug 16, 2009 | 10:24 AM
Alan 71's Avatar
Alan 71
Hi H,
My guess is the little rubber bumper has finally dried out enough and fallen off the stop. So you're having metal to metal contact when the doors close that you're feeling (if you're in the car) and hearing. Maybe?
Regards,
Alan
Old Aug 16, 2009 | 11:27 AM
...Roger...
Originally Posted by Alan 71
Hi H,
Regards,
Alan
Oh your working on the "slam".
Alan-what rubber bumper? I can think of a bumper for the up position but not one for the down.
Old Aug 16, 2009 | 12:01 PM
haybail's Avatar
haybail
Cruising
Default head lights slaming shut
head lights slaming shut when I close them, the red hoses are on the relays and a will check for the rubber bumpers, can not see any cracks in the hoses, may have to getting a vacumm gauge.
Haybail
Old Aug 16, 2009 | 12:20 PM
Mike Ward's Avatar
Mike Ward
If you meant that they close with a 'bang' and look like they could cut your finger off, that's normal- they're supposed to work like that.
Old Aug 16, 2009 | 02:58 PM
...Roger...
If they are faster than what you have been used to in the past the mechanism could need lubricated or adjusted. If the overcenter locking mechanism is binding or sticky and doesn't move the instant the actuator try's to move it the actuator will build up more vacuum and sorta "wind up" so to speak and when the mechanism does let go it can be fairly violent. Hope that made sense.
Old Aug 17, 2009 | 04:26 PM
haybail's Avatar
haybail
Cruising
Default 1975 corvette head lights
I tired what you suggest, I sprayed the bearings, slides and the overcenter locking mechanisms, both headlights work nice and smooth, I used W-40 Thanks for the help !!!!!!!!!!!
Haybail
To head lights
