And then....
Old Aug 20, 2009 | 05:44 PM
hdpete98's Avatar
hdpete98
Default And then....
On my 71 the carb inlet started leaking, stripped out with a self taping inlet from previous owner, so I rebuild the carb with new heli-coil. And then... why not add a new Edelbrock manifold and replace the cut fuel line with a NOS line. Everything is pack together and it starts up and then the ignition switch sticks. So I order new lock and then.... figure I should go ahead and put in new ignition switch. And then... I should change the rag joint since the steering column is out And then.... I should just detail the column since it is out.... And then......someone stop me before I end up with a frame off.
Old Aug 20, 2009 | 05:54 PM
rydoc's Avatar
rydoc
You may as well ... while your there it just doesn`t stop.
Rod
Old Aug 20, 2009 | 06:12 PM
CCrane65's Avatar
CCrane65
Originally Posted by hdpete98
On my 72 the carb inlet started leaking, stripped out with a self taping inlet from previous owner, so I rebuild the carb with new heli-coil. And then... why not add a new Edelbrock manifold and replace the cut fuel line with a NOS line. Everything is pack together and it starts up and then the ignition switch sticks. So I order new lock and then.... figure I should go ahead and put in new ignition switch. And then... I should change the rag joint since the steering column is out And then.... I should just detail the column since it is out.... And then......someone stop me before I end up with a frame off.
If that column isn't a tilt/tele now is the time.
cc
Old Aug 20, 2009 | 06:31 PM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
And Thats how it started with the restoration of my #'s matching 68/427....
http://s289.photobucket.com/albums/l...20Restoration/
Old Aug 20, 2009 | 06:34 PM
72LS1Vette's Avatar
72LS1Vette
I can tell by the sequence of things that you have done that you are a lost cause. Might as well start building the body dolly.
Rick B.
To And then....
