Calyx Manifold Dressing
Old Aug 26, 2009 | 02:09 PM
Leung's Avatar
Leung
Default Calyx Manifold Dressing
Does anyone know if I can use this on my 81 headers? They're stock but I'm not sure if they're cast iron or what not. Anybody ever used this before?
Old Aug 26, 2009 | 02:54 PM
Ward72's Avatar
Ward72
On cast iron exhaust, it worked great.
Old Aug 26, 2009 | 03:28 PM
...Roger...'s Avatar
...Roger...
I'm pretty sure your headers are stainless. What does Calyx say about stainless ?
Old Aug 26, 2009 | 03:34 PM
Leung's Avatar
Leung
Just called and they said it won't work on stainless because there arent enough pores. He said it will work on steel and cast iron.
Old Aug 26, 2009 | 03:56 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
i used it on my car it's AWESOME looks great /easy to apply, I used a dab on my fingers not the brush..... !!!
Old Aug 26, 2009 | 04:10 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
its a wast of time and money. it doesn't last and it will ruin any cloths
Old Aug 26, 2009 | 04:33 PM
RagTop69's Avatar
RagTop69
How long does it last? Is it very expensive per application? How many applications do you get out of a single container?
Old Aug 26, 2009 | 04:45 PM
Ray Y's Avatar
Ray Y
Did mine 3 years ago and still looks fine without further touch up. I do however only put about 2500 mi/year on my car. Even used it on the master cylinder with good results. It took about 1/3 of a small container of it.
Old Aug 26, 2009 | 04:51 PM
Leung's Avatar
Leung
The product comes in a 3 oz. jar, pretty small. Not sure how many applications you can get out of it but one container is enough for a set of headers. Here's a pic
Also can anyone confirm that this is stainless steel? If not any ideas what it is? Stock headers on an 81.
Thanks!
Old Aug 26, 2009 | 05:32 PM
7T1vette's Avatar
7T1vette
IF your cast iron manifolds are clean and free of any dirt or oil (you can wire-brush off the loose rust/scale, Calyx will work pretty well for a few months. If there is oil on the part, the Calyx will flake off with any touch/rubbing at all, once it cures from the header heat. If you don't want to remove the manifolds, Calyx is a viable option. It is easy to do with a very stiff bristle brush and if you allow for a sore back from bending over that much. If you remove the manifolds, wire-brushing or bead blasting, using tack rag to get loose stuff off, then professional ceramic coating or shooting with Seymour Cast-Blast ceramic paint will give you the long-term good, cast iron looks that you are after.
Old Aug 26, 2009 | 05:44 PM
...Roger...
I think I remember putting a magnet to the AIR part of the manifold but don't remember if I tried the header part. Your header part looks pretty rusty so maybe its not stainless or its not rust free stainless. Can you weld stainless to other metals ?
What are those tiny holes in your vacuum tube going to the heat riser actuator ? Bleed off ?
Old Aug 26, 2009 | 06:03 PM
rvazquez's Avatar
rvazquez
St. Jude Donor '24-'25-'26
Old Aug 26, 2009 | 06:52 PM
Leung's Avatar
Leung
Not sure what those tiny holes are for. I am by no means a mechanic.
However I applied calyx on my master cylinder. It only took about 10% of the container, maybe less. Still waiting for more responses on the headers. Here are some pics of before and after:
Old Aug 26, 2009 | 06:56 PM
694speed350's Avatar
694speed350
Looks like good stuff.
Old Aug 26, 2009 | 07:00 PM
Leung's Avatar
Leung
has a minty smell to it too!
Old Aug 26, 2009 | 07:27 PM
427SIXPACK's Avatar
427SIXPACK
It lasted pretty long on my car, it's not expensive at all & takes almost no time or effort to do,
so I dont understand what it is your referencing ???
BTW..............it's not supposed to be used on "CLOTHES" it's called "MANIFOLD DRESSING"
not CLOTHES / DRESSING !!!
Old Aug 26, 2009 | 07:43 PM
cargo247's Avatar
cargo247
Yes they are stainless steel.
To Calyx Manifold Dressing
Old Aug 26, 2009 | 07:44 PM
rajsid's Avatar
rajsid
Calyx is strictly for cast iron ONLY.
Your headers are made of steel. Get them ceramic coated or paint them with POR high temp paint (not the POR manifold paint).
Jethot does good ceramic coating, but there should be plenty of local places that will do a good job.
Old Aug 26, 2009 | 10:35 PM
Mad Vette's Avatar
Mad Vette
I like the way your master cyl turned out. And 81 had factory headers? Thats awesome.
Old Aug 26, 2009 | 10:46 PM
rajsid's Avatar
rajsid
I don't think any year corvettes had factory headers.
To the OP's original question.. No the headers are not stainless steel. SS does not rust.
