Rear sway bar on the BBs. Half shafts and yokes might be bigger. Front sway bars were usually a little bigger.
Purchase the 71 assembly instruction manual (AIM). The AIM will show everything needed for the factory installation of a big block in a '71 Corvette. It will also have notes on the installation, the original part numbers, where the option varied from the base car and where it did not, etc.
Use what you find in the AIM to put together a parts list of what you'll need for the swap.
I own a small block '71 and was curious about the differences between the small block and big block cars other than the engine. I am very happy with my matching numbers small block.
If I really need a rush i take out the 69 Camaro with the 502 big block and Tremec 5 speed manual.
red line different on the tach, front spring specs, emissions sticker above the master cylinder.. radiator support is different size, caps on the half shafts, rear stabilizer bar, i think the front stabilizer bar is a notch thicker, console data plate, certain cars had different fuel lines
Base SB used a metal 'tube' type radiator shroud. SB with A/C used the same rad shroud as the BBs. Build differences are dependent on options selected, as well as whether it's a SB or BB.
