aluminum prep
Old Sep 4, 2009 | 10:54 PM
1976 corvette's Avatar
1976 corvette
Default aluminum prep
I have read that there is special prep to use like a phosphoric acid before painting aluminum like the bell housing. If you don't prep the aluminum first it risk the paint not sticking as long. How did you guys paint your aluminum parts? Anything produces you used?
Old Sep 4, 2009 | 11:55 PM
earthquake68's Avatar
earthquake68
Clean and dry the part in solvent. (the "dry" part is super important.) Even cast parts I'll sand down. Usually so they're smooth. (lotsa work) then a good epoxy primer or etching primer as a base. Sealer and a top coat and you're all set.
Old Oct 20, 2009 | 12:01 AM
1976 corvette
I have looked around for a while now and yet to have found someone who has use phosphoric acid before painting to acid etch the aluminum. I am getting my information from a aircraft painting book. Is there any factor why aircraft aluminum would be diffent for something like the aluminum on the bell housing or fan?
Old Oct 20, 2009 | 12:21 AM
71coupe454's Avatar
71coupe454
A brand of wheel cleaner called Gold Eagle might do what ya want. Its for non-clear coated wheels and says etching formula on it. Works great on intakes to clean them. It leaves a etched surface on smooth/polished alum parts
Old Oct 20, 2009 | 01:31 AM
noonie's Avatar
noonie
I use oshpo to prep all metals for paint including aluminum.
Then use zinc chromate primer for alum, hard to find, but the right stuff, same as aircraft.
Old Oct 20, 2009 | 02:04 AM
Mad Vette's Avatar
Mad Vette
That's what self etching primer is for earthequake68 gave you the right answer the first time. Don't use zinc chromate, take it from an old aircraft mechanic it's dangerous stuff that's why it's banned in half of the United States that's why its so hard to find.
Old Oct 20, 2009 | 09:29 AM
7T1vette's Avatar
7T1vette
No problem to get here in Tennessee. And it...duh...don't do us no harm...duh....
Old Oct 20, 2009 | 02:11 PM
jimvette999's Avatar
jimvette999
I sand blast with fine sand, wash & dry immediately and prime/paint. Sticks well to the slightly roughened surface, gives the primer/paint a mechanical bond.
Jim
Old Oct 20, 2009 | 09:28 PM
1976 corvette
Thanks everyone for the help
To aluminum prep
