Hood damage
Old Sep 6, 2009 | 09:24 PM
1976 corvette's Avatar
1976 corvette
Default Hood damage
I bought a 75 parts car and thought all was good until I saw the underside of the hood. The nuts that are in the left lower part of the hood that connect to the hing has been yanked out. I don't have a picture of it but there is just a whole were it is box around in red. Has anyone else had this problem before? Is there any kits to repair it?
Old Sep 7, 2009 | 10:36 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
There is a plate with weld-nuts for attaching the hood bolts in that area of the hood reinforcement panel. If you have the missing pieces, you might be able to repair the area. Otherwise, you'll need a hood or the necessary repair parts off a junker.
Old Sep 7, 2009 | 10:48 PM
1976 corvette
Does no one sell that plate?
Old Sep 7, 2009 | 10:59 PM
Goody's Avatar
Goody
Try the vendors to your left <<<<<<<----------{{{{{{{{
Old Sep 7, 2009 | 11:07 PM
earthquake68's Avatar
earthquake68
If you give me the dimensions of what you need, I could make it for you. Install is up to you. Seems like an 1/8" plate with nuts welded to it would do the trick. I could make it long so it would slide into the stiffener rib, then pull it back so the whole metal piece would be inside the rib and spanning the weak spot. Follow me? Then just 'glass into place.
'just a thought.
Old Sep 8, 2009 | 08:29 AM
pbcanney's Avatar
pbcanney
'just a thought.
You do custom fab work?
Old Sep 8, 2009 | 08:30 AM
earthquake68
yup.
Old Sep 8, 2009 | 08:39 AM
pbcanney's Avatar
pbcanney
yup.
you got pm
Old Sep 8, 2009 | 09:58 AM
Easy Mike's Avatar
Easy Mike
Probably not. It's part of the reinforcement panel bonded to the underside of the hood.
Old Sep 8, 2009 | 03:14 PM
1976 corvette
Thanks earthquake68 for the offer but I can make one myself. I just wanted to know if anyone sold it before I made one of my own.
Thanks everyone for the help
To Hood damage
