L48 Cooling
Old Sep 7, 2009 | 08:54 PM
Vmaxkid's Avatar
Vmaxkid
Default L48 Cooling
Can anyone tell me why when I open the radiator cap on my 78 L48 PC it is not full to the top (actually empty to the overflow line) but my 78 L48 SA is full to the top when opened? And the PC has leaked out of the cap. I replaced it but it still seems to leak just slightly but the overflow is fine. And the PC has a 16lb. cap when the SA has a 15lb. cap. If I want to keep the PC cooler in traffic should I switch to the 15lb?
Old Sep 7, 2009 | 09:35 PM
mds3013's Avatar
mds3013
Is there a hole or crack in the hose from the radiator to overflow tank? A leak here would prevent the rad. from refilling when the coolant cooled off. One pound of cap pressure should not make much difference. Cap needs to have a valve in the center that allows coolant to return from tank. mds...
Old Sep 8, 2009 | 07:30 AM
Mike Ward's Avatar
Mike Ward
Changing cap rating will not affect operating temps, just the point where the coolant will boil.
Old Sep 8, 2009 | 11:31 AM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
The new cap could be defective.Change it again and see what happens.
Old Sep 8, 2009 | 01:27 PM
7T1vette's Avatar
7T1vette
If the L-48 engine does not have an overflow tank, you have to leave expansion room in the radiator for the water when it heats up. The mark on the upper tank is the FILL level mark on that kind of system. Your '78 car has an overflow tank. With that kind of system, the radiator is completely filled and the o-flow tank is filled to it's FILL line. The water expansion is then taken up by the o-flow tank, rather than the radiator.
To L48 Cooling
