Making progress...PICS!
Old Sep 9, 2009 | 11:48 AM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Default Making progress...PICS!
This is my first restoration and it is taking more time and money than I originally thought. Trying to do a frame on is difficult but that is all I can afford or am able to do. Oh well. Here are some pictures...
Scraped a lot of undercoating off the floor pans.
There was 40 years of grease on the crossmember.
The engine has been completely rebuilt...zero time...balanced and bluprinted. It has a Comp Cams 268H grind in it with .020 over pistons. Made sure only the heads were shaved and not the block. Can't mess with that stamp pad!
Pulled 408 HP and 500 FT-LBS on 93 octane.
Centered the bellhousing with Moroso offset pins. Don't want that clutch to chatter.
New LUK clutch and pressure plate. The flywheel was resurfaced.
Hated to overspray the orange, but "Factory to Boxcar" was the method they used at Tonawanda back in 1969, so NCRS wants to see it. I guess the exhaust manifolds will burn theirs off.
Just mounting loose parts to clear the shelves and awaiting re-installation. Plan on trying to install with the tranny (also rebuilt)attached and the radiator support frame in place.
Old Sep 9, 2009 | 12:16 PM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
Very Nice It brings back memories of when I finished rebuilding/restoring my #'s matching 68/427..Isn't it a great feeling seeing the progress you make day by day of it going back together.
Old Sep 9, 2009 | 12:44 PM
RMVette's Avatar
RMVette
That is one good looking engine! I didn't realize that the bell housing was only painted half way down plus the exhaust manifolds are painted. I learn something new every day.
Old Sep 9, 2009 | 12:53 PM
larryg3's Avatar
larryg3
looking great!!!
Old Sep 9, 2009 | 01:05 PM
silver69's Avatar
silver69
Your motor looks fantastic, wish mine was a big block!
Old Sep 9, 2009 | 01:10 PM
OURSHARK's Avatar
OURSHARK
The engine looks nice, you are doing nice work. Keep us posted.
Old Sep 9, 2009 | 03:24 PM
72ls5fla's Avatar
72ls5fla
Im not to sure the manifolds are supposed to be painted in 1969.
I was looking at the 68-69 TJM and it read more like very early 1968 might have some orange overspary where the bolts are but then Tonowanda quit spraying the manifolds&engine as an assembly up through 1974 production.
Otherwise - DAMN nice job!!!!!!
Old Sep 9, 2009 | 04:01 PM
Alan 71's Avatar
Alan 71
Hi FR,
Thanks very much for the interesting pictures. I always enjoy SEEING what people are working on.
I started work on my 71 thinking the body would stay on the frame, but changed my mind as I progressed.
Quite a nice pad surface.
Regards,
Alan
Old Sep 9, 2009 | 04:27 PM
Faster Rat's Avatar
Faster Rat
The 68-69 judging manual just says the "bell housings should have some orange paint overspray." Mine originally had less coverage than this, along with a whole bunch of big drips, like the spray gun was sputtering, over the unpainted portions as well as the clutch fork.
The judging manual also says "some post-1968 427 engines had orange paint on the exhaust manifolds and appear to have been painted at Tonawanda with the exhaust manifolds in place." Mine still had yellowish paint residue on them.
I've seen old black and white photographs of them spray painting these engines on the open 427 assembly line, with the manifolds in place and they didn't even use breathing masks. They evidently did not spend a lot of time doing this.
Old Sep 9, 2009 | 04:49 PM
72ls5fla's Avatar
72ls5fla
I can vouche for the bell housing painting -
I had very little coverage on the bottom side and it was applied very quickly everywhere else
My shifter fork had orange dusting on it, it was directional from the front to the rear.
As for the manifolds - the TJM is a guide. It does not mean that other variations did not happen. It sounds like your engine had paint applied at Tonowanda.
Hell - I put plenty of things back the way I found them durring my restoration. Some of them did not match the TJM and I took a couple point hits for it. For me - reassembling as it was found is WAY more important.
Please keep posting pictures - awsome job!!!
Old Sep 9, 2009 | 04:56 PM
rajsid's Avatar
rajsid
Originally Posted by Faster Rat
Nice....
Old Sep 9, 2009 | 05:43 PM
vettebuyer6369's Avatar
vettebuyer6369
Great pictures... nice pad.
Old Sep 9, 2009 | 06:32 PM
killain's Avatar
killain
Oldtimer
All I can say is "Wow" Now that looks nice. Of course I'm a NCRS member, so basic stock is in my blood. Very nice !
Old Sep 9, 2009 | 07:11 PM
Faster Rat's Avatar
Faster Rat
Originally Posted by Alan 71
Hi FR,
Regards,
Alan
Hi Alan
I can guarantee you that I will not pull the body...unless I win the lotto. The "while I'm at its" are really busting the bank. I haven't even contemplated starting on the back end yet. I really need to finish the front end, clear the parts off the shelves and empty my brain. This fastener thing (documenting, cleaning, media-blasting, bagging and labeling) and all the other re-plating (hood support, hood brackets, clutch shaft, "parkerized" floor pans, etc) really add to the job. The stuff that can be done later (like accessible from the top) will just have to wait for another day.
Old Sep 10, 2009 | 01:34 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
That is beautiful work, Faster Rat.
I am always fascinated by the engineering and assembly involved, back in the day as well as your efforts to date.
If I had the resources, it would be a fun (in a macabre-sort-of-way) to attempt a "correct" restoration of one of these cars.
Good luck and keep sharing your progress. We enjoy watching the car develop!
Old Sep 10, 2009 | 02:31 PM
miguel1973's Avatar
miguel1973
looks fantastic
Old Oct 12, 2009 | 09:15 PM
Faster Rat's Avatar
Faster Rat
Default More Progress
Here are some more pictures:
Preparation for painting
Engine compartment
Crossmember
Chart from engine dyno
Bored .020 over, forged pistons, Comp Cams High Energy Series, grind #268H with hydraulic lifters, valves, springs, resized rods and crankshaft, etc. Ran with stock carb and 93 pump gas. We used an HEI distributor on the dyno because my rebuilt stock points distributor fell a little short. Plan on trying something with the coil after the engine is installed in the car.
To Making progress...PICS!
