Classic or Antique
I'm not worried at all about the paint. It's Steel Cities Gray all around, so nothing crazy there. -Neal
Classic motor vehicle—A self-propelled vehicle, but not a reproduction thereof, manufactured more than 10 years prior to the current year and because of discontinued production and limited availability, determined by the Department to be a model or make of significant value to collectors or exhibitors, and which has been maintained in or restored to a condition which is substantially in conformance with manufacturer specifications and appearance."
"§ 67.3. Application for antique or classic registration plates.
(a) Application. Application for antique or classic registration plates shall be made on forms issued by the Department.
(b) Supplemental documents. The application shall be accompanied by four color photographs—front, rear and both sides—of the vehicle for which the application is being submitted. The photographs shall be clear and the condition of the vehicle easily ascertainable from them. The photographs shall be submitted in accordance with instructions provided by the Department.
(c) Additional information required for classic vehicles. If a vehicle is to be registered as a classic, the applicant may be required to provide the Department with documentation that one or more of the following conditions has been met:
(1) The production of the particular make or model has been discontinued.
(2) The vehicle was manufactured as a limited edition or is otherwise of limited availability.
(3) The vehicle is of a model or make that is of significant value to collectors or exhibitors.
(4) The vehicle is substantially in conformance with manufacturer specifications and appearance so as to qualify for participation in organized club activities, exhibits, tours and parades.
(d) Other means of transportation. An applicant for antique or classic registration shall maintain regular registration on another motor vehicle for personal transportation. If the registration is not maintained the applicant shall sign an affidavit indicating the type of transportation that he uses on a regular basis."
-Neal
I guess that's why the PA DMV added this to the bottom of their form: "Antique vehicles operated exclusively between sunrise
and sunset are exempt from the normal lighting requirements of the Pennsylvania Vehicle Code but must have their original
lighting equipment."
Basically this means to me that as long as my lights work the way they were supposed to work in 1977 I'll be ok. My only concern is the dang exhaust. We will see what happens I guess! -Neal
As stated in the last post, you CAN drive it at night because it has all the modern lighting. Both of the tags state that it's use is for shows parades, and "occasional" driving(read as weekend driving). They are both one time payment tags. The biggest difference is that antique tags do not require an inspection, were as classic requires a yearly inspection. For this reason I would go for antique(inspections are a pain)The car MUST be as it left the factory. I know people that have been rejected because they had a vanity plate(corvette,chevy,phillies,steelers.. .ect) on the front.(only rear plate needed in PA in case others are wondering) I'm not sure if they will notice the antenna, but don't be surprised. Only thing to do is give it a try and see what happens.
I have a couple cars with PA antique plates and a couple with PA classic plates. I drive them all fairly regularly and at all hours and I have never had a problem in 18 years. Annual inspection with the classic plate is the only difference.
They ARE sticklers with the photos though and usually know their stuff. However, sometimes they get their facts wrong, like when it comes to C3 luggage racks. If your car looks pretty stock in the photos, you should be okay. Not that I condone it, but I do know of people who have sent pics of correct cars very similar to their own with the logic that they could plead that they made modifications afterwards if an issue ever comes up. Not that I condone doing this...
Terry
http://forums.corvetteforum.com/c3-g...ion-in-pa.html
http://forums.corvetteforum.com/c3-g...que-plate.html
http://forums.corvetteforum.com/c3-g...-question.html
Believe it or not, I went with Classic plates so my regular garage looks at it, if I want them to, for safety inspection, plus I wanted to give them some income on the 'vette in addition to my other vehicles.
This has worked out well. They did an excellent 4 wheel alignment for their regular price. They lent me an engine hoist when I was changing engines, and other special tools I needed. They also have some sort of expensive on line service for trouble shooting newer cars, that I have used in the past. No charge and I fix most things myself.
It is good to have a local garage you trust, and they trust you.
