70 LS5 Advice
Corvettes sparked my intrest lately and needing a break from restoring my Chevelles anyway, I stumbled onto this car...
http://s369.photobucket.com/albums/o...70%20Corvette/
70 Corvette LS5 454/390 horse. Engine is matching numbers. M21, but not the original trans. 3.55:1 posi rear.
It's frame-off restored with black powder coated frame, black painted a-arms, new ploy bushings in all a-arms, new front springs, new composite aftermarket rear leaf, aftermarket adjustable rear links, slotted and drilled aftermarket rotors, new master cylinder, new power booster, new brake lines (but not stainless steel) rebuilt steering box, new gas tank and sending unit.
Rebuilt engine, std. bore, using original 10.25:1 pistons, new rings, bearings, etc., using original rods, and crank, new Comp solid lifter cam close to the factory specs, new timing set, new valve springs, 3 angle valve job.
Doesn't smoke or drip any fluids. Owner says it has about 800 miles on it since restoration.
Transmission has new gears, synchros, seals, etc. in the transmission. Has new front case because the one he started had broken ears.
Rebuilt rear-end with new seals and bearings.
New seat covers, seat foam, carpet, door panels, console top, weatherstripping, etc. All gauges work and are accurate except the clock. Aftermarket AM/FM cassette radio.
Horn doesn't work but the owner says the relay clicks.
Backup lights don't work. Owner not sure on why.
It has new wiring harness for front lights, and engine compartment.
The bodywork was done by a professional shop. They had to install another windshield frame from a donor car. This worries me a little about t-top fitment, but owner says that they got it right. The fiberglass is in good shape and doesn't show signs of stress cracks.
The shop took it down to the gelcoat and repainted it with a newer 2008 Dark Blue (GM color). Base coat / clear coat. However the original color is Mulsane blue. The hood underside is also painted the body color and not original black.
So what do you guys think it's worth??? Especially since it's not back to 100% stock..suspension upgrades, brake upgrades, different color, not matching trans, etc.
The owner is looking for at least $28,000.
I'm not from the Corvette community so I don't know much about them. I could say I was born and raised on Chevelles, and I'm wanting to explore a little. I want a companion to my 69 and 72 Chevelles. I wonder how a Corvette will fit in? haha
Hey thanks guys, I appreciate you taking the time to read through my post and post your own opinion.
-Dan
Although a lot of work was done to the car, not too many people are willing to pay big dollars for car that's been slightly modified in many areas. I think it would be a REAL stretch to pay $28,000 for the car.
Regards,
Alan
PS: I'm a VERY stock guy.... I'm thinking $18k.
Yes, there are other cars perhaps for a couple thousand less out there, but it can take you a lot more time and effort to find one, inspect it to confirm its condition, and then deal with the hassles of actually buying it.
If this one fits YOUR budget, and you like the condition of it, then definitely buy it; it sounds like it's a great car that needs a small bit of work, and you'll be hard pressed to buy better at that price.
And if anyone says that it's much too expensive, tell them they have to back it up with links to cheaper cars in equal condition that you can buy right-now with the same ease that you can buy this one...
Regards,
Alan
I know the market is down for collector cars in general, so I'm aware that I'm going to have a very difficult time selling my original non restored '71 LS5 Convertible with so many nice restored C3's for sale.
I'm leery to even ask on this forum what my car is worth.
Good luck Dano383
Good luck Dano383
The old days of "this '71 is painted a '75 color. It's a parts car" are over (thankfully).
My comments above have no more to do with the NCRS than the old 'numbers matching car having more value than a NOM car' never ending argument. You may not agree or care for your own car, but many many potential purchasers do. It's the buyers that set the market value, not the NCRS.
BTW- 'paint must be lacquer' statement for NCRS is not correct.
