What is a "Muntsi" transmission?
Old Oct 10, 2009 | 04:19 PM
The13Bats's Avatar
The13Bats
Default What is a "Muntsi" transmission?
"1975 Corvette Stingray. Engine in great shape!
Lockout muntsi Four speed transmission. (lockout Muntsi = You lock reverse so you can't go into reverse. Mainly used for Racing purposes. Since reverse is right next to first gear there's no accidents while racing.) It's ready to rebuild and drives perfectly otherwise! It's a project that anyone can finish!
Only $3500!"
http://orlando.craigslist.org/ctd/1415087038.html
Do you believe he means ""muncie" ?
Old Oct 10, 2009 | 05:42 PM
John 65's Avatar
John 65
Yes....GM used those....... along with some Worg Barner trannys. Happens to the best of em !
Old Oct 10, 2009 | 05:47 PM
LT1driver's Avatar
LT1driver
it is MUNCIE
Old Oct 10, 2009 | 06:36 PM
ctgene's Avatar
ctgene
Banned Scam/Spammer
When I was a kid our family used to drive by the Borg Warner factory in Muncie, IN on the way to my uncle's home. My uncle worked there as a machinist.
Old Oct 10, 2009 | 07:10 PM
Alan 71's Avatar
Alan 71
Hi Bats,
I believe it's a misspelling.
I think it's spelled MUNSTI.... It was a special transmission George Barris made for the custom he made for the T-V show THE MUNSTERS.
You remember that car/trans....right?!?!
Regards,
Alan
Old Oct 10, 2009 | 07:15 PM
Ganey's Avatar
Ganey
though it was too much for them!
Old Oct 10, 2009 | 08:39 PM
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
I don't know BATS, you may want to jump on that one for your project. You're probably not going to find one with that unique type trans again.
Old Oct 10, 2009 | 08:46 PM
7T1vette's Avatar
7T1vette
There aren't many "Muntsi's" around anymore...
Old Oct 10, 2009 | 09:57 PM
3JsVette's Avatar
3JsVette
Offer this guy 2.5K and this guy http://sacramento.craigslist.org/cto/1410616316.html 5K and you have your 7.5K project car.
I really do understand your frustration looking at these "project" cars. These people will drive you crazy. You really know exactly the kind of thinking ( or lack of thinking) you're up against as you're reading the seller's discription. Keep posting it makes for good discussion.
Old Oct 10, 2009 | 10:07 PM
randommj's Avatar
randommj
Originally Posted by LT1driver
it is MUNCIE
ok, its bugged me long enough, how is it pronounced?!
Miles
Old Oct 10, 2009 | 10:13 PM
bb62's Avatar
bb62
Miles
Mun (as rhyming with "bun") - cie (as in the letter "C" or from "sea to shining sea").
Old Oct 10, 2009 | 10:37 PM
markids77's Avatar
markids77
Yup, one of them M24 "nut crusher" transmitters. Use to see 'em in Trans National races; you know, all them Camaros and such like with the acid tripped lightweight bodies!
Old Oct 10, 2009 | 10:51 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
It has to be a Muntsi transmission, no Muncie that needs a rebuild is worth $3500
Old Oct 10, 2009 | 11:34 PM
BobbyC3's Avatar
BobbyC3
From: Common courtesy and common sense are not common.
Muncie rock crusher M22 transmission
Old Oct 11, 2009 | 12:10 AM
rajsid's Avatar
rajsid
I used to have a 78 vette with a lockout Muntsi.
Sometimes it used to get locked in the reverse and wont go forward unless you go under the car and unlock the linkages.
Old Oct 11, 2009 | 12:26 AM
Solid LT1's Avatar
Solid LT1
I think he meant MUNCHIE 4 speed, they tend to grind and growl a little, they just need a little thicker gear lube than Muncie 4 speeds run about 240WT should do it
Old Oct 11, 2009 | 05:41 AM
RunningMan373's Avatar
RunningMan373
Hey, that's not a bad price for a '75,, if the frame and cage are in good shape, if you know or have a friend who knows how to paint,, L82 too.
To What is a "Muntsi" transmission?
Old Oct 11, 2009 | 08:15 AM
schmegeggie's Avatar
schmegeggie
Got to admit, that's a little funny Bats...
Old Oct 11, 2009 | 10:37 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Muncie trannies are made in America.
Muntsi trannies are foreign repros.
Old Oct 11, 2009 | 12:21 PM
URNXT's Avatar
URNXT
I was born at Ball Memorial. Super T-10 in the 73. Saving the original M- 21.
