'70 LT1 engine
Old Oct 21, 2009 | 08:23 PM
minuteman71's Avatar
minuteman71
Default '70 LT1 engine
I am looking at a '71 coupe to modify for racing with an LS engine I already own. The car currently has a '70 LT1 engine which I would remove and sell. Anyone have any idea what this engine is worth?
Old Oct 21, 2009 | 08:26 PM
7T1vette's Avatar
7T1vette
Not with so little information about it.
Old Oct 21, 2009 | 08:28 PM
mstanton's Avatar
mstanton
It's going to depend greatly on how complete the engine is. Some of the parts are fairly expensive; alternator, carb, TI system, AIR system. What's the information on the stamp pad?
Old Oct 21, 2009 | 08:44 PM
minuteman71
I am working off pictures and am not going to see/drive the car until the weekend. The AIR system is MIA, the valve covers are aftermarket and as it is a non-stock install I am assuming the intake, carb and alternator are not OEM. I was trying to factor in the value so I could figure out what I could afford to pay. If no ballparks are forthcoming I will post details when I get back from seeing the car. Thanks for patience.
Old Oct 21, 2009 | 08:51 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
so what is making this a LT-1 and not just another 350. it seems everyone who I ever talk to about there hot rod chevy 350's say it was a LT-1 too.
Old Oct 21, 2009 | 09:12 PM
66L36Coupe's Avatar
66L36Coupe
Buying an as-built, used engine is a huge gamble for anyone. Figure the real-world Obama-era value as the equivalent for the sum of it's parts, less 50%.
Not trying to bust your bubble, just reality as there are a lot of guys who need to liquidate their part stashes, coupled with the fact that cash talks.
Old Oct 21, 2009 | 09:22 PM
Ironcross's Avatar
Ironcross
and its real value is with the parent Vette not someone elses if any value at all...otherwise is`s another 350 on the market...
Old Oct 21, 2009 | 09:25 PM
minuteman71
That is what I need to hear. I shall factor $0 and go from there.
Just curious, were the LT-1 blocks the same as the other 350s?
Old Oct 21, 2009 | 09:27 PM
LT1driver's Avatar
LT1driver
ironcross is right, worth squat unless still with the original car, if a true LT-1 you should keep motor for future restore or leave car as is an sell for profit and get a regular vette to modify, my opinion only.
Old Oct 21, 2009 | 09:28 PM
Nowhere Man
All the same you are looking for a LT-1 suffix code on the stamp pad the is a factory stamp. anything after that its just another 350
Old Oct 22, 2009 | 08:15 AM
7T1vette's Avatar
7T1vette
Proper stamp pad code will tell you if the block has 4-bolt main caps (as LT-1's had). The rest of the internal differences are crank (material), pistons and rods, solid lifters and camshaft. Externally, the differences are carb (Holley instead of Q-Jet), intake (aluminum), valve covers, larger exhaust manifolds/pipes (2-1/2"), and 3-line fuel pump. So, all you really have telling you that is an LT-1 engine is the sellers words... Talk is cheap.... Check for proper codes on the engine block pad; but all you can be certain of from that is the 4-bolt mains....all else could have been changed in the past. The most likely scenario is that the prior seller told the present seller it was an LT-1 engine; and he 'bought' it....literally.
Old Oct 22, 2009 | 09:13 AM
GD70's Avatar
GD70
Look for these stamped codes on the pad on a 70 block:
CTK
CTR
CTU
CTV (ZR-1)
Block cast # should be 3970010
Glenn
Old Oct 22, 2009 | 09:34 AM
thread baron's Avatar
thread baron
CTK
CTR
CTU
CTV (ZR-1)
Glenn
I would think if the block/heads match up as an LT-1 you would be better off from a financial standpoint to hold onto the motor in case you want to sell the car in the future.
Old Oct 22, 2009 | 06:51 PM
Alan 71's Avatar
Alan 71
Hi TB,
I think you missed that the engine is for a 70 but the car is a 71. Otherwise ... good point.
Regards,
Alan
Old Oct 22, 2009 | 07:14 PM
Ironcross's Avatar
Ironcross
Originally Posted by Alan 71
Hi TB,
Regards,
Alan
then it really belongs to nothing or everything, and could also be nothing unless it was a GM crate replacement and no vin number stamped on it...The 70 engine was the most desired one of the three however.....
Old Oct 22, 2009 | 08:38 PM
Kustom8's Avatar
Kustom8
I disagree about the engine not having any value away from it's owner.350s are a dime a dozen,but if it is a REAL coded 70 LT1 then it will be desired,and worth waaaaay more than a regular 350,even if the other 350 is 4 bolt.It's about the code.
I have a 69 DZ 302 engine that has been decked.It is the rarer of the block castings,good nickle,good 2448 caps,correct balancer,etc.,and it won't bring squat cause the little DZ code is gone.The same engine w/the original DZ stamp...even though it will be incorrect for EVERY potential buyer will bring waaaay more than my engine.
It does matter.Look on ebay,and you will see if it matters.Those guys restamp the vin portion on the block,look for era correct,or just bragging rights.Whatever the case...it will pull more money.
Old Oct 22, 2009 | 08:51 PM
Grumpy 427's Avatar
Grumpy 427
Now a days with new cylinder head and camshaft technology, The days of looking for 30 yr old hp parts are over. My engine builder has a nice little crate motor he builds with a set of truck 882 castings, that makes 360 HP and 390 tq. Its a 2 bolt main block, but its plenty strong for my application. Having said that, in my opinion, a 70 LT-1 is worth what someone is willing to pay for it. Now if your looking for a numbers correct engine for a resto then someone will pay just to have it.
Old Oct 23, 2009 | 09:02 AM
thread baron
Hi TB,
Regards,
Alan
Ha! Correct Alan, I missed that one....I was getting excited that he was about to let a good egg leave the nest.
Thanks for the pick up!
To '70 LT1 engine
