Blower upgrade templet
Old Nov 28, 2009 | 10:32 PM
71coupe454's Avatar
71coupe454
Default Blower upgrade templet
Anybody thats going to change thier blower to a c4 blower, here is a templet for the spacer thats needed. If you print it out, make sure the center hole is 5-3/4" and it will fit perfect.
Old Nov 29, 2009 | 08:50 PM
929nitro's Avatar
929nitro
Is there a certain thickness this has to be? Any other changes needed? Thanks.
Old Nov 29, 2009 | 09:08 PM
'75's Avatar
'75
Here is one I saved from another site with the measurements on it.
Old Nov 29, 2009 | 10:49 PM
79 vette head's Avatar
79 vette head
St. Jude Donor '10
im going to start doing mine. from what i've seen and been told about one inch should do it
Old Nov 30, 2009 | 09:47 AM
Aggitated Monkey's Avatar
Aggitated Monkey
I just installed a blower in mine. Did know about the C4 blower. What does the C4 blower do for us?
Old Nov 30, 2009 | 02:52 PM
7T1vette's Avatar
7T1vette
It has a better fan design and more airflow (or so we're told).
Old Nov 30, 2009 | 03:01 PM
FRSTR90's Avatar
FRSTR90
Please let us know if you see a huge advantage over the stock blower motor.
Old Nov 30, 2009 | 04:56 PM
RunningMan373's Avatar
RunningMan373
Old Dec 1, 2009 | 10:57 PM
71coupe454's Avatar
71coupe454
I think 3/4 is going to do it from what I eyeballed... got sidetracked with a few other things last several days. From what forum members have said, the longer blower fan moves more air. I dont know if the motor is any different or not. My blades were cracked up some so I thought I'd give it a try and see.
Old Dec 1, 2009 | 11:40 PM
chvet73's Avatar
chvet73
Mibe is 3/4" and works fine. The closer to the bottom the fan is the more airflow. I made mine from black ABS 3/4" plastic I got from McMasterCarr. Don't even have to paint it.
Old Dec 2, 2009 | 10:08 PM
Aggitated Monkey
Does anyone have a comparision photo of the C3 and C4 fans? My new motor from Advance Auto fit perfect, however it came with a white plastic or nylon fan that appeared to be an inch wider. I reinstalled my old fan on the new motor. I do not get the high speed when high is selected. When high is selected it goes to low speed.
Old Dec 2, 2009 | 10:57 PM
71coupe454's Avatar
71coupe454
I can look again tomorrow but I think it was just longer than my original but I'll take a pic and post it, its all laying out on my workbench.
Old Dec 3, 2009 | 12:59 PM
Maco Shark's Avatar
Maco Shark
That is probably your "high speed relay" malfunctioning.
Its an easy fix.
Old Dec 4, 2009 | 11:27 PM
C3-76's Avatar
C3-76
When you complete the project please post a follow up. I am having low air flow issues from a 76 and would like to know if this helps.
Old Dec 11, 2009 | 10:32 PM
UHF's Avatar
UHF
Any results to post?
Old Dec 11, 2009 | 10:46 PM
UHF's Avatar
UHF
Old Dec 12, 2009 | 12:30 AM
71coupe454's Avatar
71coupe454
Well I for one, have got no where.. I got side tracked with carb. issues, ended up buying a new Holley, got that on and burned up my points in the process because I have the ignition wired direct to a battery so I can run it on a stand. So my dash and heat/ac systems are all still in a thousand pieces all over my work bench.
Old Dec 12, 2009 | 01:03 AM
79 vette head
St. Jude Donor '10
cant seem to find any time right now. might have to wait untill i get the car back from paint shop. not that i want to do this job after getting the car painted but i might have to...
Old Dec 12, 2009 | 09:14 AM
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
Same here. The blower motor was weak before I dissassembled the car and this is still on the "to get" list. If the C4 proves to be better, I'll go that route.
Terry
To Blower upgrade templet
