brake ? inside
Old Dec 3, 2009 | 08:31 PM
73 454's Avatar
73 454
Default brake ? inside
Alright...I know there are a hundred threads on brakes around here so I figured I'd post one more.
So I've replaced EVERY piece on the system and the pedal still gets squishy and goes to the floor. I'm at a lost ideas. The pedal still feels the same as it did before I started swapping out pieces.
The master cylinder/booster/calipers/the little rubber lines up front/short hard lines in back. So I don't know what to do next.
Please help!
Old Dec 3, 2009 | 09:03 PM
Corvettetodd's Avatar
Corvettetodd
Did you bench bleed the Master Cylinder before you installed it?
Old Dec 3, 2009 | 09:14 PM
oldsarge's Avatar
oldsarge
dumb question but did you bleed the whole system as well. Can you see any signs of leakage front to back?
Old Dec 3, 2009 | 11:32 PM
72LS1Vette's Avatar
72LS1Vette
If you already know that there are hundreds of threads on brakes why don't you try searching some of them for the answers? There are only so many problems that a brake system can have and the threads have provided solutions to every one of them. There is a sticky on brakes in the Tech section that might help you out.
Rick B.
Old Dec 4, 2009 | 09:58 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Check run out at all four corners. If you have replaced everything and air continues to enter the system, the problem is likely to be run out.
Old Dec 4, 2009 | 11:45 AM
73 454's Avatar
73 454
We bench bled the master, the whole system and no leaks were found.
Someone was telling me about the rod length in the booster might be different. Could that be true?
Old Dec 4, 2009 | 01:03 PM
BB72's Avatar
BB72
It only takes a second for you to find out. You realize these threads drive all of us crazy. Buy a motive bleeder and push the fluid through. I made a similar tool and it worked great. I tried gravity bleeding, vacuum bleeding, pumping with the pedal which just locks the directional valve, none of that worked like the positive pressure to the master.
Old Dec 4, 2009 | 01:45 PM
Easy Mike's Avatar
Easy Mike
...Someone was telling me about the rod length in the booster might be different. Could that be true?
Yes. Was your master cylinder Corvette specific, or a generic? That could affect pedal travel, but would not account for air in the system (mushy brakes).
To brake ? inside
