tire paint?
Old Dec 10, 2009 | 11:07 PM
miller6t9's Avatar
miller6t9
Default tire paint?
anybody ever tried to paint the letters white on a set of tires? reason I'm asking is: I have a chance to get a set of radial T/As cheap but the letters were colored black with a sharpie. any ideas?
Old Dec 11, 2009 | 12:04 AM
70Donnybrooke's Avatar
70Donnybrooke
I remember years ago I had a motorcycle that I painted the letters white. It was a paint pen that I think I got at pep boys. I do remember I had to re apply it every now and then. I know Duplicolor has different colors. Here is their site :
http://www.duplicolor.com/products/hottires.html
Old Dec 11, 2009 | 04:40 AM
GREGG-73's Avatar
GREGG-73
Here is another paint pen you can try. I've been very pleased with it.
http://www.sakuraofamerica.com/?q=solid-marker
Old Dec 11, 2009 | 07:47 AM
lvrpool32's Avatar
lvrpool32
The raised white pletters are basically white rubber moulded to the side of the tire. Try using some original Goof Off on a rag on the letters, if not some laquer thinner (just don't bathe the tire in it!)
Old Dec 11, 2009 | 08:48 AM
GREGG-73's Avatar
GREGG-73
You should do the above first prior to appling the paint pen....(as once you get black paint pigments in the white rubber...its impossible to get them back to a new look, with thinner's or whatevever). But you should remove as much as you can & clean the surface as best you can, for best result's. Also, I have found that if the paint pen and tire's are at ambient temp or higher, the application is much easier. In other words...don't try to apply the paint pen on a cold day or in an unheated garage. One winter, I actually did mine in the kitchen...needless to say.... that went over well with the wife....
Old Dec 11, 2009 | 09:08 AM
7T1vette's Avatar
7T1vette
Do as described above to get the raised letters as free of ink as possible; then place a sponge or rag soaked in bleach on them for a few minutes. See if that helps remove the discoloration. If not, you can try to sand the lettering down to remove the discolored surface. If the ink soaked in too deep, you'll have to re-color them to save them. If you decide to 'paint' them, use some bright white SEM 'Color Coat'. It will stick to vinyl/plastics, leather, and rubber products. Use a small brush and apply with care so you don't get it on the sides of the raised letters.
Afterthought: You know, you might be able to use an ink pad (get new, 'clean' pad at craft store in the stamp-pad area) to put some white dye in..then 'stamp' the new color onto the surface of the letters. If you do that lightly and carefully, that shouldn't put dye onto the sides of the letters. And, you could give it several coats that way to get full color onto them.
Old Dec 11, 2009 | 12:32 PM
dugcyn's Avatar
dugcyn
the above is correct on all tires i have worked with. the letters are molded in white. you can steel wool them or scotch brite scrub them and will look as new when the top layer is removed.
scrub flat to the face or you will reveal white on the sides of the letters..
Old Dec 11, 2009 | 01:15 PM
427basketcase's Avatar
427basketcase
Try it.....You'll like it.......
Old Dec 11, 2009 | 01:49 PM
rajsid's Avatar
rajsid
This is awesome. Red line tires... anybody?
Old Dec 11, 2009 | 04:12 PM
BB72's Avatar
BB72
As I've did with many of my Goodyears, the white rubber goes deep. All you need to do is take a sander and clean it up. I've did it with many of my weathered white lettered tires. The lettering is the first to go.
Old Dec 11, 2009 | 09:05 PM
3JsVette's Avatar
3JsVette
Originally Posted by 7T1vette
You can try to sand the lettering down to remove the discolored surface.
White letters are like white walls and run very deep. You have to be carefull with the edges though. Make sure you sand flat and use a sanding block or similar as stated above.
Old Dec 11, 2009 | 09:55 PM
OURSHARK's Avatar
OURSHARK
I have used lacquer thinner for many years to clean the white letters. It is fast and easy. It should take off the sharpie ink.
Old Dec 12, 2009 | 12:44 AM
71coupe454's Avatar
71coupe454
was trying to think of how they spelled it then I got down to this. I would try this first, with a little water and a scrub brush. If that dont work I'd try the sanding/buffing to get fresh white rubber exposed. Not saying it cant be done, but any time I seen someone try and paint letters it looked tacky as hell.
To tire paint?
