Two Questions on Total Timing
Old Jan 20, 2010 | 08:39 PM
Lemans Blue 69's Avatar
Lemans Blue 69
Default Two Questions on Total Timing
Own a 1969 L46. 350 cu, 350 hp, 380 ftlbs. Read Lar's article and another's on total timing in great lengh. Both suggest to remove the springs from the weights in the distributor prior to setting the distributor for total timing..
One suggested to hold the weights back with elastic bands while doing the setup and the other made no such mention on holding the weights back.
Question 1:Which way should I do it?
Both suggested weaker springs be installed if total timing can't be achieved with the original springs reattached with rpm running at max of 3000 give or take.
Question 2: If springs need to be replaced, where can they be purchased and aren't there different spring strenghs?
Thanks,
John
Old Jan 20, 2010 | 08:56 PM
Frank O'Hara's Avatar
Frank O'Hara
I would listen to Lars - I sent my distributor and carb to him a few years ago to rebuild them and it made a huge difference
Old Jan 20, 2010 | 09:03 PM
Lemans Blue 69
Frank, Believe total timing is accomplished with the distributor in the car and it is running. Would be a good trick if it could be done otherwise. Thank you for the reply.
John
Old Jan 20, 2010 | 10:01 PM
ksbunting's Avatar
ksbunting
John,
I too sent my carb for my 68 LeMans blue Corvette to Lars.
He tunes them and then actually installs them on a car at his location to set them up just the way they should be. Then he removes it and sends it back to you.
He only did my carb, I did not get a chance to send him my distributor and then he stopped doing work for others because he wanted to spend more time on his own projects, the last I heard.
By the way, welcome to the Forum.
Kurt
68 t-top L79
Old Jan 20, 2010 | 10:38 PM
Lemans Blue 69
I asked just two questions and haven't received a reply to either question. Can anyone answer the questions? If not, just don't post.
My Best Regards,
John
Old Jan 20, 2010 | 11:44 PM
glassman74's Avatar
glassman74
Thanks,
John
John,
(1) I used Lars paper. Worked the best. He knows his stuff.
(2) Any speed shop will have them.
glassman74
Old Jan 20, 2010 | 11:45 PM
noonie's Avatar
noonie
Using no springs allows you to verify the absolute max mechanical advance with no interference from springs. Note it and check it again with the springs you test. Some springs won't allow full adavnce.
Using the elastic bands allows you to verify that the springs you are using completely remove any mechanical advance at idle. Sometimes the weaker springs do not fully retract and creat idle problems. I just use duct tape.
They come as an advance kit assortment from any speedshop or Jegs, Summit or even distributers from other manufacturers like Chrysler etc as long as they retract fully.
This is the way I do it, others may differ.
Old Jan 21, 2010 | 01:35 PM
lars's Avatar
lars
I DO NOT recommend removing the springs - you are reading an obsolete paper - did you download it from the Internet? Do not use any of my papers posted on the Internet - request current papers from me directly by e-mail request:
V8FastCars@msn.com
Removing the springs will cause an over-advanced condition that will not be duplicated with the springs installed, and you will end up with insufficient total timing. You set total timing with the engine running, but you can remove ONE spring if you have the stock springs in order to lower the total timing point to a safe observable rpm. Do not remove both springs or use any rubber bands.
Lars
Old Jan 21, 2010 | 02:32 PM
Lemans Blue 69
Lars, I did get it from the internet as well as the other one that said to use rubber bands. I will take you up on the offer and email you for the current papers.
Thankyou for the reply. Guess this answered my 2 questions.
Thanks,
John
To Two Questions on Total Timing
