That depends a lot upon how well you plan the swap and whether you have all the hardware needed to do it in one shot. It also depends on whether you can make some of your own brackets/hardware or whether you have to buy a kit to get that done.
Your best 'friend' is good planning: knowing exactly what you will have to do...down to the last bolt...and the sequencing of doing the work. Just consider all the 'peripheral' issues that need to be done: driveshaft differences? speedo cable change? speedo gear change in new tranny? all the clutch pedal and linkage alterations? If you have all of that figured out and know exactly what you need to do for that change, it's still a PITA because of the pedal changes. But planning will make it go a lot easier. And who cares about cost? If that's what you want in your car...do it. Or sell that one and buy what you really want.
I agree with 7T1; know what you're doing before starting the job. Purchase the '78 assembly instruction manual (AIM) and compare the factory installations of each. Swapping is more involved than you might think.
Every situation is different though many basics are the same. Your planning should take into consideration the "while-I'm-at-it" routine, too. The project can easily cascade into a full-blown frame-off without thinking about all the variables involved. It's happened for less reasons than yours.
Good Luck and keep us posted what you choose to do.
Check out Keisler transmissions, they offer a complete kit for converting your automatic Corvette to a 4 speed. I'm guessing around 2700-3000 for the kit.
I've done the switch twice, on a 73 and a 80. Fairly easy to do, just collect all the parts you will need. Nothing really complicated, the pedal switch is not as hard as some say, in my opinion. A friend did this switch on a 73 and bought all the parts from one person on e-bay for $1000, including the 4 speed muncie trans. It will probably cost you more unless you can find some deals on the parts. I think it is a fun project, go for it if you have the time, money and mechanical ability. Good luck!
Not sure of where you live, but if your in the snow belt, you have a good six weeks to get it done. Got 12" of snow today, so no vettes on the street for a while.
Personally if you are going to go through all that trouble and expense then do it right and get at least a 5 spd. You can then add better gearing to the car to really improve the overall driving experience.
Exactly right and good advice. We hear stories like this all the time. Guys try to save some cash (a good thing) and go with a Muncie, Saginaw or BW 4 speed instead. Things are fun for a while until the desire for an overdrive hits.
You`re on the right track though. Do your research and compare costs, there`s lots of info to be had here on the forum.
i would find a corvette junk yard that has a complete 4 speed set up that will work for your year .buy the complete set up .that way you have everything and trade back all the parts you dont need .i do like the 5 speed overdrive ,if its in the budget.
