hei plug gap
Old Feb 19, 2010 | 05:13 PM
tomgallucci57's Avatar
tomgallucci57
Default hei plug gap
my 68 has a 1406 edelbrock carb with a edelbrock intake, its a 327-4 speed with a mallory hei distributer, runs good,but it doesnt always just start rite up,wondering if i should change my plug gap from 35 to 45 or 55 for better starting and or better performance. what do you guys think. thanks tom
Old Feb 19, 2010 | 05:52 PM
7T1vette's Avatar
7T1vette
You should set the plug gap according to the ignition module and coil that you are using. The stock GM HEI system requires .060" plug gap. You can set it lower, but then you just lose the benefit of the higher spark potential that the HEI system can provide. Set the gap as wide as the module and coil will allow.
Old Feb 19, 2010 | 06:13 PM
tomgallucci57
ill have to get in touch with mallory to see what they say. i dont have any paper work with this distributer, the car came to me this way. thanks alot tom
Old Feb 19, 2010 | 09:34 PM
7T1vette's Avatar
7T1vette
The Mallory unit and your coil may allow you to gap it even more, but you can do .060" gap for sure.
Old Feb 19, 2010 | 10:52 PM
Mike Ward's Avatar
Mike Ward
Opening up the plug gap won't fix a hard starting engine. Do normal troubleshooting on the carb, starting with the choke.
Old Feb 21, 2010 | 09:45 AM
tomgallucci57
thanks for the replies,summer is around the corner, tom
Old Feb 21, 2010 | 11:42 AM
Ironcross's Avatar
Ironcross
Performance engines are best set at a .035 plug gap with or without electronic ignitions...all the rest are wherever you want or you think its right....
Old Feb 21, 2010 | 02:43 PM
tomgallucci57
its currently set at 35, if i open them to 60 , should i notice any seat of the pants differences,and or ill effects. just not sure what to expect from the gap change thanks
Old Feb 21, 2010 | 03:26 PM
rcread's Avatar
rcread
Why do you suspect your spark gap as being the cause of the car "not starting right up"? Does it do this after it's been sitting a couple of days? It could just be that the fuel in your Edelbrock carb is evaporating and you have to crank it until the fuel pump fills the bowl back up. Modern fuel evaporates pretty quickly.
Old Feb 21, 2010 | 04:37 PM
Mike Ward's Avatar
Mike Ward
You will notice NO positive change, maybe a possible misfire if the ignition system can't handle a .060 gap.
Old Feb 22, 2010 | 10:14 AM
tomgallucci57
my whole reason for this thread was because when i got the 68 in oct. 09 it can with the engine freshly rebuilt,only 300 miles on the engine,i would drive it every day for about a half hour,and if i would shut it off to get say , gas. it would either start right up, or become tempremental and have to crank and crank it,then you would have to pump the pedel abit, alittle bit,or it would be on the verge of flooding it,making it real hard to restart.since then ive changed the plugs,still runs real good,but still tempremental, espically at restart.thats why i was wondering if the plugs needed gaped to 60 with hei system. ill just have to have the carb dialed in and the timing checked,otherwise she flies real good. thanks again for all replies tom
Old Feb 22, 2010 | 12:02 PM
jellyjam's Avatar
jellyjam
Sounds like a Vapor Lock to me. Turning the engine off when warmed up and time to add gas and restart is enough time for vapor lock to occur. Make sure gas lines are away from engine block and you may have to add heat shield gasket under carburator. I also added an electric fuel pump near the gas tank. End of my problems on hot restarts.
Old Feb 22, 2010 | 12:50 PM
tomgallucci57
ill take all this into consideration,i never measured how much space i have between wingnut stud and inner hood for a heat shield gasket. ill investigate, thanks
Old Feb 22, 2010 | 10:10 PM
jellyjam's Avatar
jellyjam
Default Carb Gasket to insulate from heat .
Gasoline evaporates (boils) at a lower temperature than it use to. Its not as important with fuel injection. You need to find out which one fits your carb. They are usually a metal gasket between two regular gaskets
Edelbrock #9266 Carburetor Gasket- Heat Insulator, Square Bore.
E11-9266
These Edelbrock heat insulator gaskets are designed to help prevent fuel percolation in Performer series carburetors exposed to extreme underhood temperatures. They're available in both open and ported styles, and come complete with extended-length carburetor studs.
Old Feb 22, 2010 | 10:42 PM
captl27's Avatar
captl27
Spark plug gap is variable depending on motor components and is usually determined by proformance and reading of the spark plugs themselves. Racers in the past would gap plugs different for each cylinder. Starting in 73 GM went to HEI and there gap started at 40 and progressed over the years to 60. a under gapped plug could fowl and cause poor starting. Get an old service manual that has a color spark plug chart and try to match it to the good ones.
To hei plug gap
